Transfer HA,z2m, mosquitto and Zigbee coordinator
Currently i have
A: a win10 machine, with Z2M and Mosquitto standalone. HA in Virtualbox and a sonoff dongle-p.
I want to go to
B: a genericx86 HA installation with Z2M and mosquitto as Addons and a SLZ B-06Mg24.
I have tried to restore the backup from A to B. Removing the dongleP and give the SMLight the same IEEE. As i discovered and read on fora: THis does not seem be possible. I couldn´t get ZIgbee devices to repair
Then i tried to do a restore from A to B. Added mosquitto as addon, . Disable HA and mosquitto on machine A, but let Z2M running there. I checked all the ip numbers and changed them. Everything worked. Then i installed a Z2M addon on HA on Machine B and configured tit with the SMlight.After this all my devices were gone.
Efectively ther where two z2m instances both using the same mosquitto, but configure with a differnt coordinator. The idea was to repair all my device one at a time from one coordinator to the other. But this does not seem to work
Question: what would be the best approach to do this transformation?
If you do that, you need to define another mqtt topic for the second installation
See the mqtt section below
Hi, Thanks. I will give that a go.
Question: if i repair a device to the new zigbee2mqtt2, what happens to the device in HA, and the automations it is used in.
Just give it the same name as the old one, so everything keeps working
When i start it i get in the log:
Starting Zigbee2MQTT without watchdog.
[2025-04-10 17:49:54] info: 	z2m: Logging to console, file (filename: log.log)
[2025-04-10 17:49:54] info: 	z2m: Starting Zigbee2MQTT version 2.2.1 (commit #unknown)
[2025-04-10 17:49:54] info: 	z2m: Starting zigbee-herdsman (3.4.11)
[2025-04-10 17:49:54] info: 	zh:ember: Using default stack config.
[2025-04-10 17:49:54] info: 	zh:ember: ======== Ember Adapter Starting ========
[2025-04-10 17:49:54] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash: ASH COUNTERS since last clear:
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   Total frames: RX=0, TX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   Cancelled   : RX=0, TX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   DATA frames : RX=0, TX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   DATA bytes  : RX=0, TX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   Retry frames: RX=0, TX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   ACK frames  : RX=0, TX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   NAK frames  : RX=0, TX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   nRdy frames : RX=0, TX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   CRC errors      : RX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   Comm errors     : RX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   Length < minimum: RX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   Length > maximum: RX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   Bad controls    : RX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   Bad lengths     : RX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   Bad ACK numbers : RX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   Out of buffers  : RX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   Retry dupes     : RX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   Out of sequence : RX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash:   ACK timeouts    : RX=0
[2025-04-10 17:49:54] info: 	zh:ember:uart:ash: ======== ASH stopped ========
[2025-04-10 17:49:54] error: 	zh:ember:uart:ash: Failed to init port with error Error: Error: No such file or directory, cannot open port: tcp://192.168.123.35:6638
[2025-04-10 17:49:54] error: 	z2m: Error while starting zigbee-herdsman
[2025-04-10 17:49:54] error: 	z2m: Failed to start zigbee-herdsman
[2025-04-10 17:49:54] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-04-10 17:49:54] error: 	z2m: Exiting...
[2025-04-10 17:49:55] error: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
    at EmberAdapter.initEzsp (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:672:19)
    at EmberAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1538:24)
    at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
    at Zigbee.start (/app/lib/zigbee.ts:69:27)
    at Controller.start (/app/lib/controller.ts:104:13)
    at start (/app/index.js:149:5)
Any idea what is going wring here. I checked IP numbers. I added rtscts: false, but that did not make any difference
My Configuration.yaml:
data_path: /config/zigbee2mqtt2
socat:
  enabled: true
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt:
  server: mqtt://192.168.123.31:1883
  user: xxxxxx
  password: xxxxxxx
  base_topic: zigbee2mqtt2
serial:
  serial:
    baudrate: 115200
    adapter: ember
    disable_led: false
    rtscts: false
  advanced:
    transmit_power: 20
Why is socat enabled? Disable it.
