Transfer system from RPI 3 to RPI 4 by restoring a backup from RPI 3 on RPI 4 causes RPI 4 to hang
I have a system running under Home Assistant OS on a Raspberry Pi 3B. The system has been running without any problems for some time.
The RPI 3B is running the newest version of the HA software:
  • Core 2026.4.2
  • Supervisor 2026.04.0
  • Operation System 17.2
  • Frontend 20260325.7
    The following apps are installed:
  • File editor
  • Studio Code Server
  • Terminal & SSH
  • Duck DNS
The system has also some integrations: Fibaro, Homely, HACS, Miele, Google Cast ++.
I want to move this configuration to my new Raspberry Pi 4.
I have done the following steps:
  • Made a manual backup of my RPI 3B system excluding Media and Share folder and downloaded the backup file to my laptop
  • Loaded the Home Assistant image for RPI 4 on a 60 GB SD card using the Raspberry Pi Imager application for Windows
  • With the SD card inserted, the RPI 4 boots up as expected and after I while my browser shows the HA startup screen when I enter the url homeassistant.local:8123
  • On the startup screen I have 3 choices, set up a new home, restore from a local backup or restore from HA cloud
  • And here is where the problem starts. I have tried two methods and in both cases I end up with a locked HA on the RPI 4
Method 1
  • I select the method “Restore from a local backup”
  • I select the backup file that was created from the RPI 3 and downloaded to my laptop
  • From the backup file I select all the components, Settings and history, SSL certificates and the 4 apps
  • When I click Restore the restore process starts and my browser loosesthe connection to HA and is waiting to reconnect
  • But the HA never comes up again. I waited for approx one hour.
  • There are no error messages in the browser and in the terminal that is connected to the RPI 4 HDMI
  • The output in the terminal seems normal saying that the system is Ready
  • I am able to ping homeassistant.local
On the internet I found some hints saying “Restoring a backup made on Supervisor version 2026.04.0 may fail due to compatibility issues or missing add-ons that need to be installed first. It’s recommended to ensure all necessary add-ons are installed before attempting the restore
So I therefor tried method 2
  • I reloaded the SD card with a fresh HA image
  • On the startup screen I now picked the choice “Set up a new home”
  • I went through the steps: adding user, setting location ++ and I ended up with fresh running HA
  • I checked the versions of the HA software and it was exactly the same as for the RPI 3 listed in the start of this text.
  • I then installed all apps that I have on RPI 3 except Duck DNS. I dropped Duck DNS so I could connect from my browser with url homeassistant.local:8123 and not via the Duck DNS.
  • I also set up the ip4 with a static ip on the local network. (Same as the RPI 3 but a different IP)
  • Then I uploaded the backup file created on the RPI 3 stored on my laptop
  • When the backup file was uploaded I clicked on the file to do a restore, but this time I only selected the component Setting and history (not SSL certificates and none of the apps in the backup).
  • I clicked Restore and the restore process started and the browser lost connection to the HA
  • The browser kept trying to reconnect without success. I waited for approx 1 hour and still no connection on url homeassistant.local:8123 (or :8123)
  • I ended up with the same result as with method 1
  • I could ping homeassistant.local:8123
  • No error message in the browser.
  • The terminal connected to the RPI 4 HDMI looks normal saying that the system is Ready
  • But HA is dead!
What am I doing wrong here? Is it a problem to take backup from RPI 3 and restore it on RPI 4 when we have the same HA version on both units?
Regards Edgar
Sometimes it can help to restart the HA server after the backups bhas been restored, but give it time to finish the restore.
How long did you wait before you decided ‘locked up’?
I suggest starting it before bed, and check it in the morning. It can take much longer that you think and much longer than the 30 minutes it states. While using an SD card. (possibly hours)
If you had a static IP set for the Pi3 install, restoring the backup will cause the Pi4 to be assigned the same IP.
Make sure the Pi3 is powered off (or at least disconnected from the network), then check what IP is displayed on the Pi4 banner screen when you hook it up via HDMI. Note you might have to reboot your Pi4 & possibly also your router in order to get the new IP to show properly.
I managed to solve the problem which was caused by a misunderstanding of the restore process from my side.
The configuration HA that I wanted to move from a RPI3 to a RPI4 was set up with static IP4 address and DuckDNS with Lets Encrypt. To reach my HA system from the browser I had set up port forwarding on my router.
After having set up the RPI4 from scratch the default network setup is IP4 automatic, but after restoring the local backup from the RPI3 I was expecting that the also the network setup had been copied from the backup (which means same static IP4 has for RPI3). But after running the command "ha network info" on the RPI4 I released that the IP had not been copied.
So just by changing the port forwarding setup of my router to the actual RPI4 IP4 address I the new system was working without problem.
So important learning: The network setup is not copied in the backup-restore process.
Problem resolved!
Edgar
