I want to transfer my ZWave network to a different Home Assistant. I saw many people asking the same thing and I am confused by the answers. Some people suggest moving some files that are no longer there. Others say that plugging my ZWave controller into another HA device should do the trick. But then, someone said that I need to copy and move “security keys” for my ZWave devices, but no explanations on how to do that.
At the end of the day you just need the stick and the keys to be successful but as. To the actual process and where you get those depend on with what you have now.
Thank you for the suggestion. I tried it and something does not work. I migrated Z-Wave add-on as you suggested. Everything looks good and I can see all my devices in Z-Wave JS on my new HA. The Z-Wave add-on is running.
After that, I tried to add Z-Wave devices. Here is what I see:
Thank you for your help. I unchecked the option “Use the Z-Wave JS Supervisor add-on” and specified that supervisor is at ws://localhost:3000 and it works.
