Trash pickup schedule, problem with automation
I’m trying to create a trash pickup schedule that will look like the picture below.
waste
I live in sweden, and here we can choose the weekly pickup interval. We also have separate pickup for combustible garbage and food waste.
In my situation, they pickup combustible garbage every 4 weeks and food wasteevery 2 weeks.
I started with a couple of datetime inputs to hold the next pickup date for each type of garbage.
input_datetime:
  garbage_burn_date:
    has_date: true
    has_time: false
    initial: '2020-02-27'
  garbage_food_date:
    has_date: true
    has_time: false
Next I created a couple of template sensors that will calculate how many days left. It shows “Today”, “Tomorrow” or the # of days.
# Template sensors
    sensors:
      garbage_burn:
        friendly_name: 'Brännbart'
        icon_template: mdi:trash-can-outline
        value_template: >
          {% set datediff = (((states.input_datetime.garbage_burn_date.attributes.timestamp - as_timestamp(now())) / 24 / 60 / 60) | round(0,'ceil')) %}
          {% if datediff == 0 %}
            Idag
          {% elif datediff == 1 %}
            Imorgon
          {% elif datediff < 0 %}
            Datum passerat
          {% else %}
            {{datediff}} dagar
          {% endif %}
        entity_id: input_datetime.garbage_burn_date,sensor.time
    sensors:
      garbage_compost:
        friendly_name: 'Kompost'
        value_template: >
          {% set datediff = (((states.input_datetime.garbage_food_date.attributes.timestamp - as_timestamp(now())) / 24 / 60 / 60) | round(0,'ceil')) %}
            Idag
            Imorgon
            Datum passerat
          {% else %}
            {{datediff}} dagar
          {% endif %}
        entity_id: input_datetime.garbage_food_date,sensor.date
This works just as it should. However, once the date has passed, it needs to be updated. I created a automotation that will update the date few minutes after midnight each day if the date has passed.
This will work, however, after a reboot it will reset back to the initial date and will need X amount of days to catch up again.
So I changed to a template trigger that will trigger the automation if the date has passed, but I cannot get it to fire. The actual automation works if you trigger it manually.
I previously used now() in the value_template to calculate the date differance but I read that it wont fire, so I changed to sensor.date. But still wont work, perhaps I used it wrong?
automation:
  - alias: 'Garbage Update Date: Brännbart'
      value_template: (((states.input_datetime.garbage_burn_date.attributes.timestamp - as_timestamp(strptime(states('sensor.date'),'%Y-%m-%d'))) / 24 / 60 / 60) | round(0,'ceil')) < 0
    condition: []
      service: input_datetime.set_datetime
      data_template:
        date: '{{ ((states.input_datetime.garbage_burn_date.attributes.timestamp + 2419200) | timestamp_custom("%Y-%m-%d", true)) }}'
  - alias: 'Garbage Update Date: Kompost'
      value_template: (((states.input_datetime.garbage_food_date.attributes.timestamp - as_timestamp(strptime(states('sensor.date'),'%Y-%m-%d'))) / 24 / 60 / 60) | round(0,'ceil')) < 0
    condition: []
      data_template:
        date: '{{((states.input_datetime.garbage_food_date.attributes.timestamp + 1209600) | timestamp_custom("%Y-%m-%d", true))}}'
I had some bad formatting @ value_template, forgot {{ }}. However that was not the only problem.
I first used now() to get the current time and date and converted that into a timestamp. I then realised that the code does not have a sensor in it that will update, so I added a sensor.date_time.
Problem with sensor.date_time. is that you cannot convert it directly to a timestamp, does not contain a valid unix time.
Checking with the template dev tool:
{{ as_timestamp(states.sensor.date_time.state) }} will return None.
{{ as_timestamp(states.sensor.date.state) }} will return None.
{{ as_timestamp(states.sensor.time.state) }} will return None.
However, using:
{{ as_timestamp(states.sensor.date.state~' '~states.sensor.time.state) }} = SUCCESS!
