Hi all! I’m brand new to HA. I just got it installed on a Raspberry Pi via Docker, and I’m just starting to be able to see my home devices online. Something I’m curious about trying to solve to just get a feel for what’s even possible… is there some kind of hardware that would sit inline on a USB cable that could monitor voltage and pass that info to HA?
Use case: I am really impressed with the new BenQ monitor bar light. It has a built in proximity sensor that automatically turns the light on when I sit at the desk, remains on while I’m at the desk (even if there is little to no movement), and then successfully automatically turns off after a certain amount of time after I leave the desk. This device is not communicating with anything at all (no bluetooth, no wifi, no app, not even driven by USB data). It’s a completely standalone device and happens to use USB power which allows me to power it via a USB power hub (again, not a data hub). It would be awesome if there was some kind of USB (A or C) female to female coupling that monitored voltage and sent those real-time values to HA. That way, I could use a given threshold in the voltage draw that effectively represents the condition for when a person is sitting at the desk to be used as a trigger in HA. I’m assuming the threshold would be important because the device must draw a small amount of power at all times in order for its sensor to work. But then, obviously, the voltage draw would go up and down as its light fades on and off.
Before you guys beat me up about there being a ton of other proximity sensor products already on the market that are meant for exactly this, please understand #1, I’m mostly curious for the technical “yes”/“no” to if my idea is even possible for my education of learning the capabilities of this platform and ecosystem. And #2, I’m just most impressed by the snappy responsiveness and accuracy of the BenQ light’s behavior. I do also have a BigAssFans Haiku ceiling fan that also has a built-in occupancy sensor which is already visible within HA. However, it fails to correctly identify me being in the room when there is little to no movement, so leveraging that sensor’s status seems to fall short of some automation ideas I have in mind.
