Hi all,
I’m trying to turn off a “indicator” helper switch when my sensor stays below 175 for 4 mins. straight and only if the indicator switch is in the “ON” position for those 4 mins.
Here’s my attempt:
on_value:
if:
condition:
for:
time: 240s
condition:
and:
- switch.is_on: indicator
- sensor.in_range:
below: 175
then:
- switch.turn_off: indicator
- uart.write:
data: "Indicator off"
It turns off when it should, but then the uart bus randomly sends the “Indicator off” message every now and then regardless of whether the indicator switch is on or off. There’s no real fixed time interval either - eg. it will randomly send “indicator off” once after 10 mins. and then again after 2 mins., and again after another 15 mins., etc. Not sure what’s happening.
zoogara
(Daryl)
March 16, 2025, 7:50am
2
You probably need to capture some logs and post them. The whole yaml config rather than just the bit you think is the issue is also sometimes handy - unless it’s enormous…
Here’s the full code. Not sure how to access logs - when device connects to wifi, it doesn’t show up as ‘Online’ on my esphomebuilder.
substitutions:
friendly_name: "mmwave2"
esphome:
friendly_name: "${friendly_name}"
name_add_mac_suffix: true
project:
version: "3.0"
platformio_options:
board_build.flash_mode: dio
board_build.mcu: esp32c3
on_boot:
then:
- delay: 210s
- repeat:
count: 2
then:
- uart.write:
data: "AT+JOIN"
- delay: 7s
# external_components:
# - source: github://limengdu/mmwave-kit-external-components@main
# refresh: 0s
esp32:
board: esp32-c3-devkitm-1
variant: esp32c3
framework:
type: esp-idf
logger:
hardware_uart: USB_SERIAL_JTAG
level: DEBUG
api:
reboot_timeout: 0s
ota:
- platform: esphome
wifi:
enable_on_boot: false
ssid: *****
password: *****
reboot_timeout: 0s
uart:
- id: uart_bus
baud_rate: 115200
rx_pin: 4
tx_pin: 5
parity: NONE
stop_bits: 1
- id: indicator_bus
baud_rate: 9600
rx_pin: 3
tx_pin: 2
parity: NONE
stop_bits: 1
seeed_mr24hpc1:
uart_id: uart_bus
text_sensor:
- platform: seeed_mr24hpc1
heart_beat:
product_model:
product_id:
hardware_model:
hardware_version:
keep_away:
name: "Active Reporting Of Proximity"
motion_status:
name: "Motion Information"
custom_mode_end:
name: "Custom Mode Status"
binary_sensor:
has_target:
name: "Presence Information"
custom_presence_of_detection:
name: "Static Distance"
movement_signs:
name: "Body Movement Parameter"
custom_motion_distance:
name: "Motion Distance"
custom_spatial_static_value:
on_value:
if:
condition:
for:
time: 240s
condition:
and:
- sensor.in_range:
below: 175
then:
- uart.write:
custom_spatial_motion_value:
on_value:
- if:
condition:
and:
- switch.is_off: indicator
- sensor.in_range:
above: 6
then:
- switch.turn_on: indicator
- uart.write:
data: "Indicator on"
custom_motion_speed:
custom_mode_num:
name: "Current Custom Mode"
switch:
underlying_open_function:
name: Underlying Open Function Info Output Switch
name: "Occupancy Indicator"
optimistic: true
restore_mode: ALWAYS_OFF
button:
restart:
custom_set_end:
name: "End Of Custom Mode Settings"
select:
scene_mode:
unman_time:
name: "Time For Entering No Person State (Standard Function)"
existence_boundary:
name: "Existence Boundary"
motion_boundary:
name: "Motion Boundary"
number:
sensitivity:
custom_mode:
existence_threshold:
name: "Existence Energy Threshold"
motion_threshold:
name: "Motion Energy Threshold"
motion_trigger:
name: "Motion Trigger Time"
motion_to_rest:
name: "Motion To Rest Time"
custom_unman_time:
name: "Time For Entering No Person State (Underlying Open Function)"
Use an analog threshold binary sensor (inverted) with delayed on filter, set the switch off in the on_press
trigger and use the switch on_turn_off
trigger to send the log message.
Breaking out thresholds like this into separate (binary) sensors also make things way easier to debug plus you get a nice history of events.
You can always mark them as internal if you don’t want them sent to HA.
I much prefer that approach to the various on_value “range” type alternatives.
Thanks for the suggestions y’all. The analog threshold binary sensor is def. more convenient - got what I was after.
Still can’t wrap my head around why my previous code glitched. I initially thought it was UART bus related but guess not. Anywhos, glad it’s running now.
And I didn’t know we could hide sensors from HA. That’s neat. Thanks @Mahko_Mahko
Any entity without a name won’t be exposed to HA, and for internal use you don’t need a name, just an ID.
