Trigger Automation with webhook
I try to create an automation for my vaccum (Valetudo). This automation should be triggered by a webhook with the information where to clean via JSON.
In the log I can see that the automation is triggered, but nothing happens and there is no error in the logs.
I think that there is something wrong with the data_template: '{{ trigger.json.bereich }}'
Here you can see my automation:
- id: '1582208321009'
  alias: staubi_test
  description: ''
  - platform: webhook
    webhook_id: staubi
  condition: []
  - data:
      command: zoned_cleanup
      params:
        zone_ids:
        - data_template: ['{{ trigger.json.bereich }}']
    entity_id: vacuum.rockrobo
    service: vacuum.send_command
data_template is only for the service data section. Also entity_id should be placed in the service data section:
  alias: staubi_test
  description: ''
  - platform: webhook
    webhook_id: staubi
  condition: []
  - service: vacuum.send_command
    data_template:
      params:
        spot_id:
        - data: '{{ trigger.json.bereich }}'
I had an error in my automation insteat of spot_id I have to use zone_ids. This is an array!
I edited my code as you said, but nothing happend and I get no error :frowning:
This is my code:
  alias: staubi_test
  description: ''
  - platform: webhook
    webhook_id: staubi_zone
  condition: []
    data_template:
      params:
        zone_ids:
        - data: ['{{ trigger.json.bereich }}']
Are you sure you have the correct format for the zone_id’s? What integration does your vacuum come from?
If I try it without the JSON command for the zone evrything works well:
- id: '1582212412596'
  alias: test2
  description: ''
  - platform: webhook
  condition: []
  - data:
      params:
        zone_ids:
        - Flur
Well yeah, why are you adding data to your service data every time???
  alias: staubi_test
  description: ''
  - platform: webhook
  condition: []
    data_template:
      params:
        zone_ids: [ '{{ trigger.json.bereich }}' ]
Also, you can format it like this without the json so it looks identical to your normal service calls wihtout the template…
  alias: staubi_test
  description: ''
  - platform: webhook
  condition: []
    data_template:
      params:
        zone_ids:
        - '{{ trigger.json.bereich }}'
