Trigger Based Select: select_option not firing
I’m playing with a template select entity to hold a value for a cetain amount of time before reseting to default value. The idea is to trigger it with an event that contains a new value and then use select_option: to check if the trigger contains the default value, and if not run a script that waits and then fires an event with the default value. However the select_option: doesn’t seem to go off.
I’ve managed to work around this using an action: after the trigger, but I’m baffled by the behaviour of select_option:, hoping for some insight on this.
Admitedly it took me a bit to realise that select_option: is for selecting an option, however should it not still run the actions defined there?
How I expected it to work:
template:
  - unique_id: access_request_user
      - trigger: event
        event_type: user_access_request
    select:
      - name: Access Request User
        unique_id: f5ea3a02-5c00-4828-aa8f-61a88c114735
        state: "{{ trigger.event.data.user }}"
        options: "{{ ['None', 'Owner', 'User 1', 'User 2', 'User 3'] }}"
        select_option:
          if: "{{ not trigger.event.data.user is equalto 'None' }}"
          then:
            - delay: 15
            - event: user_access_request
              event_data:
                user: 'None'
            # Also tried replacing above with calling a script to handle the delay and event,
            # script never activated
            - action: script.turn_on
                entity_id: script.access_request_timeout
My work around, since select_option: is required I left a dummy event in there that I could listen for… it never fires.
template:
      - trigger: event
      then:
    select:
        select_option:
          then:
            - event: test_select
              event_data:
                option: "{{ option }}"
Any insight would be appreciated, thanks.
Functional trigger-based Template Selects are quite new, so I haven’t had time to explore them as much as the state-based variety
The configuration variable select_option holds a list of actions to execute when a new option is selected either from the frontend or through a script action… Based on how the state-based version has always worked, I would not expect the trigger to also fire the action in select_option.
This is an automation, not a template select.
Template select serves 1 purpose and 1 purpose only: Creating a select entity that can be used in the UI & in automations.
Notes about template select entities:
  1. The state is based on the template.
  2. Select option only occurs when the select_option service is called or the entity is used in the UI.
  3. There is no automated functionality that will cause the trigger to run the select_option action.
So, what gets updated with the trigger event? Just the state and options? What about a variables block… do variables get updated and stored so that the updated values are usable in select_option actions?
Variables get resolved when a trigger occurs. They are stored every time a trigger occurs and they get passed to the service whenever the service needs to be executed.
It’s a caching system basically
I think I understand… maybe. I had assumed that because select_option: is required that it was always used. action: select.select_option does make use of it and the actions within do indeed go off.
Thanks!
select option is required because the minimum entry for a select entity is a list of options with an action to change the current selected option.
The state is also required, but that’s an oversite IMO and I will likely correct that in the future. I.e. make it optional, when not provided the entity will be optimistic.
Yes, I was hoping to keep the functionality in one spot rather than using an input_select and an automation, and it does serve the purpose even if that’s not its purpose.
You could trigger off the state of the select itself to get your reset behavior:
  - trigger:
      - trigger: state
        entity_id: select.self_resetting_select
        not_to: 'Default'
        for: '00:01:00'
      - trigger: homeassistant
        event: start
      - trigger: event
        event_type: custom_select_event
        event_data:
    select:
      - name: Self-Resetting Select
        optimistic: true
        state: "{{ 'Default' if trigger.id == 'default' else trigger.event.data.option|default('Default',1) }}"
        options: "{{ ['Default','Option_1','Option_2','Option_3']  }}"
        select_option:
          - event: custom_select_event
            event_data:
              entity_id: "{{this.entity_id}}"
              option: "{{option}}"
Hadn’t though of that, works a charm. I already had the homeassistant start event in an automation as I also needed to catch event_template_reloaded, which of course can’t work inside a template that’s being reloaded.
Again, thank you :grinning:
