Trigger based sensors in templates
I’ve been successfully using the following setup in configuration.yaml:
template: !include_dir_list template/
With template sensors like these:
  - name: "Defro - Bieg Zadany Max"
    unique_id: "defro_bieg_zadany_max"
    state: >-
        states('sensor.defro_bieg_nawiewu') | int(0),
        states('sensor.defro_bieg_wywiewu') | int(0)
      ] | max }}
binary_sensor:
  - name: "Defro - Status"
    unique_id: "binary_sensor.defro_status"
    state: >-
      {% set val = states('sensor.defro_bieg_zadany') | int(0) %}
      {{ 'off' if val == 0 else 'on' }}
I’m now trying to add this trigger based sensor into my template.yaml:
- triggers:
    - trigger: state
      entity_id:
        - sensor.defro_bieg_nawiewu
        - sensor.defro_bieg_wywiewu
      not_to:
        - unavailable
        - unknown
      state: >-
        {{ [ states('sensor.defro_bieg_nawiewu') | int(0), states('sensor.defro_bieg_wywiewu') | int(0) ] | max }}
However, it doesn’t work. I’ve checked community posts and tried various approaches without success. ChatGPT failed too. I’m sure the fix is simple… Can someone help me, please?
It’s a bit hard to tell how you’ve formatted it (specific to the indenting) since you split it into multiple examples. But here’s what it should look like:
  - switch:
      - name: my template switch
      - name: template switch 2
  - sensor:
      - name: my template sensor
  - triggers:
      - trigger: some trigger
      - name: trigger-based template sensor
    binary_sensor:
      - name: binary sensor based off same trigger
  - triggers:
      - trigger: some other trigger
    binary_sensor:
      - name: trigger-based binary template sensor
With include_dir_list, each file is implictely a list entry, so remove the - in front of triggers:, the same way you did with the others.
like that? this doesn’t work - I’ve just tried it again
    state: >-
      ] | max }}
binary_sensor:
    state: >-
triggers:
  - trigger: state
    entity_id:
    not_to:
      - unavailable
      - unknown
    unique_id: "defro_bieg_zadany_max_test"
    state: >-
it throws a warning and some sensors don’t work (I have other sensors in the same file following the same structure and indenting)
if I do it like that, then I’m getting the following error:
Cannot quick reload all YAML configurations because the configuration is not valid: Unexpected error calling config validator: ‘NodeListClass’ object has no attribute ‘keys’
here’s the code:
  - sensor:
        state: >-
          ] | max }}
  - binary_sensor:
        state: >-
  - triggers:
      - trigger: state
        entity_id:
        not_to:
          - unavailable
          - unknown
      - name: "Defro - Bieg Zadany Max Test"
        state: >-
          ] | max }}
it looks like I managed to get it to work :slight_smile: thank you for all your help!
here’s the working solution:
1. update configuration.yaml:
template: !include_dir_merge_list template
2. divide sensors into separate yaml files for better control - in my case like that:
A. defro_fan_sensor
B. defro_trigger_sensors
C. defro_template_sensors
3. structure each yaml in the following way:
- triggers:
    - trigger: state
      entity_id:
      not_to:
        - unavailable
        - unknown
    - name: "Defro - Bieg Zadany Max 2"
      unique_id: "defro_bieg_zadany_max_2"
      state: >-
- sensor:
      state: >-
        ] | max }}
- binary_sensor:
      state: >-
        ] | max }}
