Trigger based templates: when do variables resolve?
I’m using some trigger based templates that get REST data and process it into multiple attributes. Several use the same code blocks so I create variables to pre-process some of the REST output to reuse in different attributes. I thought all was well until I read this in the documentation
 variables map (Optional)
Key-value pairs of variable definitions which can be referenced and used in the templates below (for trigger-based entities only).  Trigger based template entities resolve variables between triggers and actions.
(I’ve extracted the key sentence).
My question is: if the data used by the variable comes from the REST action and it is resolved BEFORE the action, where is it getting its data from?
A short extract of my template:
  - trigger:
      - platform: state
        entity_id: input_button.tideq
      - service: rest_command.tide_heights_q
        response_variable: heightsq
      - service: [there are several more]
      - variables:
          gradient: >
            {%- if heightsq.status != 200 %} {#- start by getting the query height again, plus 10 mins later #}
              {%- from 'tide_macros.jinja' import harmonic_height %}
              {%- set height = harmonic_height(when,ts,hs)|float(0) if when<=ts|max and when>=ts|min else 'n/a' %}
              {%- set height10 = harmonic_height(when+600,ts,hs)|float(0) if when<=ts|max and when>=ts|min else 'n/a' %}
              {%- set gradient = ((height10-height)*6) %}
            {%- else %}
              {% set gradient = (30*(heightsq.content | selectattr('DateTime', 'ge', (as_datetime(state_attr('sensor.tidequerytiming','query'))+timedelta(minutes=2)).strftime('%Y-%m-%dT%H:%M:00Z')) | map(attribute='Height') | first | float(0) - heightsq.content | selectattr('DateTime', 'ge', as_datetime(state_attr('sensor.tidequerytiming','query')).strftime('%Y-%m-%dT%H:%M:00Z')) | map(attribute='Height') | first | float(0))) %}
            {%- endif %}
            {{ gradient }}
      - unique_id: tideq
        state: "{{states('input_datetime.tidequery')}}"
        attributes:
          rate: >
            {{ gradient|round(1) }}
          flow: >
            {%- set itis = iif(gradient < 0, "ebb", "flood") %}
            {%- if gradient|abs < 0.2 %}
              Slack
            {%- elif gradient|abs > 2.0 %}
              {{"V fast "+itis }}
            {%- elif gradient|abs > 1.5 %}
              {{"Fast "+itis }}
            {%- elif gradient|abs < 0.5 %}
              {{"Slow "+itis }}
            {%- else %}
              {{ (itis+"ing")|capitalize }}
            {%- endif %}
It seems to be working, or at least it is returning credible results.
You are confusing two different variables.
The variables in the documentation extract you provided is at the same level as action, not a “child” of action. Since you have set up your variables at the end of an action sequence they will be resolved after the other actions in the sequence.
Where can I put variables?
Thank you. I hadn’t realised there were options re where to define variables.
That’s what the documentation is pointing out, the option to define variables at the root level.
