Hi folks. I haven’t been building automations much in the last few months, and when I just went to make one in 2025.12, I noticed that the Edit Trigger ID option seems to have moved. Can someone tell me where to find it?
Thanks.
Thanks.
If you haven’t set an ID yet, you won’t see it in the popup. It’s under the breadcrumbs menu of the trigger popup:
If you have set it already it will show in the Trigger popup:
Thanks for adding this! ![]()
Thanks, much appreciated!
Jeff, please take the time to mark the post with the solution as the answer, you do that by selecting the three dots under the post:
Then select the check box:
By doing so:
Thanks for giving back to the community! ![]()
