Hi there,
i’m struggling creating a nodered automation for severals cast devices.
My starting point si tu trigger a flow when the “media_player” entity’s attribute is changing from true to false, and false to true. But i don’t want to trigger when the entity’s state is changing (i.e. from playing to paused), any idea on how to achieve this?
I’ve tried “events: state node” and “trigger: state node” with no luck…
Thank you, you lead me on the path…
for this is_volume_muted attribute, there’s the need to set property type to boolean… however this is what’s workig for me!
Another way to do this is to use an events: all node. In the node, you’ll place information in the event data field to match against the resulting payload object.
I have some sensors that I created which have a state of either “Due”, “Overdue”, or “No.”
In the Events: all node, the data field looks like this:
"old_state": {
"state": "Overdue"
"new_state": {
"state": "No"
This information is nested under “events” in the payload object and it only allows messages through for which this matches.
