Hi at all,
i use HomeAssistant in virtual machine with Linux as HA CLI with OS Version 17.1 and Core Version 2026.2.2
I have two shelly plugs in my house and I want to get 2 new values for each shelly.
First: Time when trigger is set (last time)
Second: When trigger comes, time range between last trigger and this trigger.
It is a pump with a power value. When power value comes 11:00:00 from 0 to a valid power value, this time should be stored as first value (11:00:00). When power value comes back to 0 (for example 11:00:10) and comes again at 11:02:00 to a value larger than 0, I want to see the time difference as 2minutes. It means from one time to next time that power value was changed from 0 to a value larger than 0, it was 2 minutes and this should be second value.
I created this with following code and add this to /config/configuration.yaml with Terminal window in HA.
template:
- trigger:
- platform: state
entity_id: sensor.shellyplusplugs_1_switch_0_power
- name: "Zeitintervall_Drainage_1"
unit_of_measurement: "s"
state: >
{% set from = trigger.from_state %}
{% set to = trigger.to_state %}
{% set last = states('sensor.Zeitintervall_Drainage_1') %}
{% if last in ['unknown', 'unavailable', None] %}
{% set last = 0 %}
{% endif %}
{# Initialisierung abfangen #}
{% if from is none or to is none %}
{{ last }}
{% elif to.state | float == 0 %}
{{ last }}
{% elif from.state | float == 0 and to.state | float > 0 %}
{% set diff = (as_timestamp(to.last_changed) - as_timestamp(from.last_changed)) | int %}
{% if diff < 60 %}
{{ diff }} s
{% elif diff < 3600 %}
{% set mins = diff // 60 %}
{% set secs = diff % 60 %}
{{ mins }}min {{ secs }}s
{% else %}
{% set hours = diff // 3600 %}
{% set mins = (diff % 3600) // 60 %}
{{ hours }}h {{ mins }}min {{ secs }}s
{% endif %}
{% else %}
{{ last }}
{% endif %}
- name: "Letzter_Trigger_Drainage_1"
state: "{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"
- trigger:
- platform: state
entity_id: sensor.shellyplusplugs_2_switch_0_power
- name: "Zeitintervall_Drainage_2"
state: >
{% set last = states('sensor.Zeitintervall_Drainage_2') %}
{% set last = 0 %}
{% endif %}
{{ last }}
{{ last }}
{% if diff < 60 %}
{{ diff }} s
{% else %}
{% endif %}
{% else %}
{{ last }}
{% endif %}
- name: "Letzter_Trigger_Drainage_2"
My problem is, that after storing file and restart HA, no value changed. All 4 values are “unknown”. Some trys before, sometimes I saw a value but now, all are unknown.
Can you help me or explain, what is my mistake?
Edit:
I click to Adjustments → Developer Tools → YAML → Reload Template-Entity
It is reloaded and now in my dashboard, 3 values are unknown and one value is written: Entity doesn’t found
I take a look in /config/configuration.yaml file and all 4 values are inside.
I don’t understand the problem
No not sure. It is my first time for creating source code in yaml.
I asked internet, AI and watch some examples and create this source by myself.
What should I use instead of states('sensor.Zeitintervall_Drainage_1')
For first sensor I think, this is right and for second sensor I used states('sensor.Zeitintervall_Drainage_2').
The reason I think to do this is because first sensor name is Zeitintervall_Drainage_1 and second is Zeitintervall_Drainage_2
You don’t need to check the trigger as much, since the sensor can only change based on that trigger. But if you want to keep the “defensive” code, I would modify it like this:
{% set from = trigger.from_state|default(none) if trigger is defined else none %}
{% set to = trigger.to_state|default(none) if trigger is defined else none %}
Since your current code may generate errors in the logs (btw: do you see any?)
And that’s what I mean, don’t use AI if it didn’t even know that very basic detail.
Depending on your version, it could be in the left side “developer tools” or in settings “developer tools” then press template.
It wouldn’t be possible to dump all this code in there but you can replace trigger variables with a set variable and kind off get stuff tested.
Triggered templates is hard to debug since they need a trigger to run.
I did something like this but I used date/time helpers. Then Had an automation that would right {{ now() }} to them on a trigger. So when when my washing machine door is opened it takes a timestamp and when the washing machine is finished it takes a time stamp. Then I can compare those two time stamps and determine if someone has moved the wet clothes out of the wash.
