Trigger time not working
I have the following 2 automations, but they refuse at the trigger I set up, at 21:00:00.
If I run them manually they work just fine.
What did I do wrong?
Thank you in advance! <3
- id: "Lock frontdoor at 21:00:00"
  alias: "Lock frontdoor at 21:00:00"
  description: ''
  - platform: time
    at: '21:00:00'
  condition:
  - condition: state
    entity_id: binary_sensor.door_frontdoor_contact
    state: 'false'
  - condition: state
    entity_id: lock.lock_frontdoor
    state: unlocked
  - device_id: 1b6aa0ee39f5eb4bfd094de81c40cf22
    domain: lock
    type: lock
- id: "Lock backdoor at 21:00:00"
  alias: "Lock backdoor at 21:00:00"
  description: ''
  - platform: time
    at: '21:00:00'
  condition:
  - condition: state
    entity_id: binary_sensor.door_backdoor_contact
    state: 'false'
  - condition: state
    entity_id: lock.lock_backdoor
    state: unlocked
  - device_id: 226686db690adffbbc2305ee1577dc77
    domain: lock
    type: lock
Remove the quotes around false change false to ”off” wrapped in quotes
It just doesn’t trigger. The automation works if I run it manually?
How come changing false to “off” would somehow trigger it? Just trying to understand :slight_smile:
The condition is failing, it’s triggering but your condition is impossible to pass because binary sensors have a state of on or off, not true/false
I shouldn’t have doubted you, it works, thank you!!
- id: "Turn on hallway lights when doors are opened one hour before sunset"
  alias: "Turn on hallway lights when doors are opened one hour before sunset"
  description: ""
  - platform: state
    entity_id: binary_sensor.door_living_contact
    attribute: contact
    to: false
  - platform: state
    attribute: lock_state
    to: unlocked
  - platform: state
    attribute: contact
    to: false
Follow-up question, these should be changed to "on"/"off" as well, in stead of true/false?
Yep true false isn’t really used much in ha. Make sure you quote them too
