{{trigger.topic.split('/')[2]}} not working for MQTT subscribing
I am finding it difficult to resolve this issue and I would be grateful for any help. I have two raspberry pi 3’s running home assistant. Hassbian1 is the primary controller and hassbian2 is in MQTT communication with hassbian1.
To subscribe to the times for a pump to start from hassbian2 to hassbian1 I have the following automation in hassbian1:
- alias: MQTT subscribe input_datetime command
    - platform: mqtt
      topic: 'hassbian2/input_datetime/pool_start_time/state'
    - platform: mqtt
      topic: 'hassbian2/input_datetime/pool_stop_time/state'
    - service_template: "input_datetime.set_datetime"
      entity_id: "input_datetime.{{trigger.topic.split('/')[2]}}"
      data_template:
        time: "{{trigger.payload}}"
This comes out as “Valid YAML” in yamllint.com. But it produces the following error:
hassbian1 hass[2556]: 2019-10-03 22:14:12 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: not a valid value for dictionary value @ data['action'][0]['entity_id']. Got "input_datetime.{{trigger.topic.split('/')[2]}}". (See /home/homeassistant/.homeassistant/automations.yaml, line 125). Please check the docs at https://home-assistant.io/components/automation/
If I change the line:
to:
entity_id: "input_datetime.pool_start_time"
this works fine, but of course only updates the pool_start_time, not the pool_end_time.
I have used {{trigger.topic.split(’/’)[2]}} in a different context in other automations:
- alias: MQTT subscribe input_boolean command
  initial_state: 'true'
    - platform: mqtt
      topic: 'hassbian2/input_boolean/automated_pool_pump/set'
    - platform: mqtt
      topic: 'hassbian2/input_boolean/turn_on_pool_for_specified_duration/set'
    - platform: mqtt
      topic: 'hassbian2/input_boolean/start_pool_set_times/set'
    service_template: "input_boolean.turn_{{trigger.payload | lower}}"
    data_template:
      entity_id: "input_boolean.{{trigger.topic.split('/')[2]}}"
and this works fine.
All advice gratefully received.
Move the line containing entity_id below the line containing data_template.
Many thanks @123 for an amazingly quick reply. I changed the service action to:
      data_template:
and it is working just fine!
Thanks again, much appreciated.
FWIW, the custom of this forum is to mark the original post offering the functional solution with ‘Solution’. Marking your own post containing a copy of the offered solution is misleading.
However, it you feel more comfortable marking your own post as the Solution, so be it.
Very sorry @123 I had presumed marking “Solution” signified the end of the thread. I have moved the Solution tick to your post. Thank you for your advice and the for providing the solution.
