I have a bigger blueprint with many trigger but this specific trigger doesn’t work.
I have reduced the code to the problem.
My goal is, to trigger the automation if the specific entity with a number is above or below a value for a given duration. All these parameters should be configurable as inputs of the blueprint.
Blueprint:
blueprint:
description: delete me
domain: automation
input:
sun_brightness_entity:
name: Sun Brightness Entity
selector:
entity:
filter:
- domain: input_number
sun_brightness_min:
name: Sun Brightness Minimum
description: Nur wenn die Helligkeit der Sonne über diesem Wert liegt, wird beschattet.
default: 49999
selector:
number:
min: 0
max: 200000
unit_of_measurement: lx
delayed_sun_brightness_to_high:
name: Delay Sun Brightness to high
description: Verzögerung, wenn die Helligkeitsschwelle überschritten wird.
default:
minutes: 2
selector:
duration:
delayed_sun_brightness_to_low:
name: Delay Sun Brightness to low
description: Verzögerung, wenn die Helligkeitsschwelle unterschritten wird.
default:
minutes: 15
selector:
duration:
mode: queued
triggers:
- trigger: numeric_state
entity_id:
- !input sun_brightness_entity
for:
hours: "{{ delayed_sun_brightness_to_high.hours }}"
minutes: "{{ delayed_sun_brightness_to_high.minutes }}"
seconds: "{{ delayed_sun_brightness_to_high.seconds }}"
above: !input sun_brightness_min
entity_id:
for:
hours: "{{ delayed_sun_brightness_to_low.hours }}"
minutes: "{{ delayed_sun_brightness_to_low.minutes }}"
seconds: "{{ delayed_sun_brightness_to_low.seconds }}"
below: !input sun_brightness_min
actions:
- action: notify.torsten_telegram
metadata: {}
message: Trigger ausgelöst
Automation to test the Blueprint:
alias: Test Trigger
description: ""
use_blueprint:
path: own/test_trigger.yaml
input:
sun_brightness_entity: input_number.test_trigger
sun_brightness_min: 11416
hours: 0
minutes: 1
seconds: 0
hours: 0
minutes: 1
seconds: 0
I changed the entity “input_number.test_trigger” to 100.000, waited 5 minutes, changed it to 0, waited 5 minutes, …
But the automation never gets triggered.
Regarding the documentation and the samples in this forum that I found, I’m not able to see the error in this code.
How can I debug a automation trigger, if it never gets fired?
Is it possible to see the “processed” code where the variables of the blueprint are replaced by the values?
Does someone see what’s wrong here?
Thanks a lot
Torsten
