I have built two automations that are almost identical. One is triggered off of an input_boolean and it works. The other is triggered off of a sensor and it does not work (it is never triggered).
Here is the input boolean and sensor definitions from configuration.yaml
input_boolean:
jeremy_home:
initial: off
# my custom presence sensor for Jeremy and Nichole
sensors:
jeremy_home_away:
friendly_name: "Jeremy Home"
value_template: "{% if is_state('input_boolean.jeremy_home', 'on') %}Home{% else %}Away{% endif %}"
nichole_home_away:
friendly_name: "Nichole Home"
value_template: "{% if is_state('input_boolean.nichole_home', 'on') %}Home{% else %}Away{% endif %}"
This trigger does work:
- platform: state
entity_id: input_boolean.jeremy_home, input_boolean.nichole_home
to: 'on'
This trigger does not work:
- platform: state
entity_id: sensor.jeremy_home_away, sensor.nichole_home_away
to: 'home'
The obvious workaround for this specific case is to just use the input_boolean as the trigger. I would like to understand why the sensor trigger doesn’t work. Any ideas?
