Triggering delay in automation
I am taking my first stab at automating one of my wemo insight switches to turn on when the Amcrest camera in the room senses motion. Once the light has been turned on if the camera doesn’t sense motion for 15 minutes the light turns off. I have the automations working, however, when the automation triggers to turn off the light after 15 minutes the camera senses it as motion and is triggering the light on again. Is there any way to disable the first animation or build in some sort of delay to prevent this “switching loop” from occurring?
- alias: Turn on Kid's light during the day when motion is sensed
  hide_entity: False
    platform: state
    entity_id: sensor.amcrest_motion_detected
    to: 'True'
 #Trigger only between 10am and 7pm
  condition:
    condition: time
    after: '10:00:00'
    before: '19:00:00'
    service: switch.turn_on
    entity_id: switch.wemo_insight__kids_room_
- alias: Turn off Kid's light after 15 minutes without motion
  hide_entity: False
    platform: state
    state: 'on'
  condition:
    condition: state
    state: 'False'
  # Trigger only if state was this for last 15 minutes.
    for:
      minutes: 15
    service: switch.turn_off
Thanks in advance.
You could change the action for the “turn off” to the following (check the automation id, I’ve never used aliases with quotes, so don’t know how it translates)
    - service: homeassistant.turn_off
      entity_id: automation.turn_on_kids_light_during_the_day_when_motion_is_sensed
    - service: switch.turn_off
    - delay: '00:00:01'
    - service: homeassistant.turn_on
Basically, when it’s time to turn the light off, turn off the automation that turns the light on, turn off the light, pause for one second, then turn the automation back on. You may not need the delay, or it may need to be longer, depending on your motion sensor’s speed.
I use something very similar for a door sensor and lights, such that it’s the opening of the door that turns on the lights, but the second closing of the door that turns them off again.
Great! That’s what I was hoping, but I wasn’t sure if i would be able to invoke multiple actions off a single trigger. I’ll give it a shot when I get home from work and let you know.
worked like a charm. thank you.
Hi
I used your method to work my automation but surprisingly I cannot get it to work. What I mean is that after the sensor has detected motion and the lights are on via MQTT (433mhz) I want them to be on for 10 seconds before they turn off after the last motion. My automation is as follows:
automation:
- alias: Bedroom Lights Motion On
    platform: mqtt
    topic: home/433toMQTT
    payload: "15139978"
   entity_id:
    - switch.bedroom_lights
- alias: Bedroom Lights Motion Off
    platform: mqtt
    payload: "15139978"
    - delay:
        seconds: 10
      entity_id: switch.bedroom_lights
Any help will be appreciated please.
Can I ask you what state is ‘false’ ? does that mean that when no motion is detected or is it the last motion which is detected?
It looks like the trigger is the same for both automations. I’ve not used MQTT triggers, but that doesn’t seem right to me.
You may, given the way you’re doing this, need to use scripts as shown here. That way every time you detect motion, you’re restarting that timer.
so I done some changes in my code and remove the motion sensor to turn off the lights, here it is:
    platform: state
    state: 'on'
    - delay:
        seconds: 10
I am trying to switch off the lights after 10 seconds as soon as they are on but surprisingly it doesnt work and the lights remain on. Cannot understand what am I doing wrong?
Got it working here is my code:
automation:
    platform: mqtt
    payload: "15139978"
  condition:
    condition: time
    after: '00:45:00'
    before: '06:00:00'
   entity_id:
    platform: state
    state: 'on'
      entity_id: automation.bedroom_lights_motion_on
    - delay: '00:10:00'
    - delay: '00:00:01'
I have the same problem and tried using the same approach without any luck. When a zone is switched on the master relay must be turned on 5 seconds later. Where do I put the “Delay”?
  • alias: ‘Master on when Zone on’
    - entity_id: switch.Zone1
    platform: state
    to: ‘on’
    - entity_id: switch.Zone2
    platform: state
    to: ‘on’
    - entity_id: switch.Zone3
    platform: state
    to: ‘on’
    - entity_id: switch.Zone4
    platform: state
    to: ‘on’
    - entity_id: switch.Zone5
    platform: state
    to: ‘on’
    - entity_id: switch.Zone6
    platform: state
    to: ‘on’
    - entity_id: switch.Zone7
    platform: state
    to: ‘on’
    - entity_id: switch.Zone8
    platform: state
    to: ‘on’
    - entity_id: switch.Zone9
    platform: state
    to: ‘on’
    entity_id: switch.Master
try the following:
alias: 'Master on when Zone on’
platform: state
to: ‘on’
platform: state
to: ‘on’
platform: state
to: ‘on’
platform: state
to: ‘on’
platform: state
to: ‘on’
platform: state
to: ‘on’
platform: state
to: ‘on’
platform: state
to: ‘on’
platform: state
to: 'on’
delay: ’00:00:05'
Thank you for the suggestion. I tried that but then the automation does not load.
Did you copy paste the code? The spacing and syntax is not correct.
No I realized the syntax and spacing was wrong but it still did not load the automation.
It looks like you are using different types of ‘. Try making sure it is all the same, at least at each state.
Otherwise you could try smal letter for Z and M in the entity_id
I tried changing the Z and M to lower case and made sure that all the ''s are correct. It still doesn’t work. I also tried adding a hyphen to the front but no luck.
I manage to get this working by adding a “for:” to each trigger entity. My code is as follow:
- alias: 'Master on when Zone on'
     - entity_id: switch.zone1
       platform: state
       to: 'on'
       for:
         seconds: 5
     - entity_id: switch.zone2
       platform: state
       to: 'on'
       for:
         seconds: 5
     - entity_id: switch.zone3
       platform: state
       to: 'on'
       for:
         seconds: 5
     - entity_id: switch.zone4
       platform: state
       to: 'on'
       for:
         seconds: 5
     - entity_id: switch.zone5
       platform: state
       to: 'on'
       for:
         seconds: 5
     - entity_id: switch.zone6
       platform: state
       to: 'on'
       for:
         seconds: 5
     - entity_id: switch.zone7
       platform: state
       to: 'on'
       for:
         seconds: 5
     - entity_id: switch.zone8
       platform: state
       to: 'on'
       for:
         seconds: 5
     - entity_id: switch.zone9
       platform: state
       to: 'on'
       for:
         seconds: 5
     entity_id: switch.master
Please help with this automation. Check from yamllint is right but nothing happen even I manually turn on input boolean.
- id: away
  alias: "Away"
  initial_state: True
  hide_entity: False
  condition:
    condition: state
    entity_id: input_boolean.sunhome
    state: 'off'
    - platform: state
      entity_id: device_tracker.sun_iphone
      state: 'away'
      for:
        minutes: 1
    - platform: state
      entity_id: device_tracker.me_sun_iphone
      state: 'away'
      for:
        minutes: 1
    - platform: state
      entity_id: device_tracker.diana_diana_iphone
      state: 'away'
      for:
        minutes: 1
- id: home
  alias: "Home"
  initial_state: True
  hide_entity: False
  condition:
    condition: state
    state: 'on'
    - platform: state
      state: 'home'
      for:
        minutes: 1
    - platform: state
      state: 'home'
      for:
        minutes: 1
    - platform: state
      state: 'home'
      for:
        minutes: 1
    - service: input_boolean.turn_off
    - delay: '00:00:10'
      entity_id: automation.away
- id: office_camera_motion_on
  alias: "Office Camera Motion On"
  initial_state: True
  hide_entity: False
    platform: state
    to: 'on'
    for:
      seconds: 5
    - service: switch.turn_on
      entity_id: switch.office_camera_motion
- id: office_camera_motion_off
  alias: "Office Camera Motion Off"
  initial_state: True
  hide_entity: False
    platform: state
    to: 'off'
    for:
      seconds: 5
    - delay: '00:00:05'
      entity_id: automation.office_camera_motion_on
I’m no expert yet but from I can see there are some indentations that is wrong. An example
for:
seconds: 5
should be
for:
  seconds: 5
I’m not sure about the double quotes (") that you use. I use single quotes (’).
Thank you very much for your reply. I will try again this evening.
