Triggering switch with weather.forecast_home_hourly
I am new to this and tried searching for related issues, but I didn’t see any.
I am simply trying to activate/deactivate my Kasa outlets in my greenhouse based on timed checks of the weather.forecast_home_hourly entity.
To activate, I have the plug set to check the weather.forecast_home_hourly every 30 minutes to see if the current temp is below 36 degrees:
alias: Tree Lights On
description: "Turn lights on to warm trees."
  - platform: time_pattern
    minutes: "30"
condition:
  - condition: numeric_state
    entity_id: weather.forecast_home_hourly
    attribute: temperature
    below: 36
  - type: turn_on
    device_id: 4ef0a41a0f39bee838dccbc223d01ba1
    entity_id: switch.right_plug
    domain: switch
mode: single
And to turn off the plug:
alias: Tree Lights Off
description: Turn off tree warming lights.
    minutes: "45"
condition:
    above: 35
  - type: turn_off
    domain: switch
mode: single
I have tested this a lot the last two weeks. The plug and lights turn off accurately, but they don’t seem to activate correctly, and I always end up manually activating the lights. Can anyone give me some tips on reliably activating these lights based on current temps?
Thank you.
That trigger is not for “every 30 minutes”, it’s for “on the 30th minute of every hour”.
Can you clarify the behavior you are looking for?
AFAIK, the attribute you are using as a condition only changes once an hour around the top of the hour, so checking it at 30 and 45 minutes past the hour is kind of pointless.
I think you want minutes: /30
What do you see in developers tools → states?
You don’t need both. entity_id: is sufficient. And a whole lot easier to remember.
Thank you for the reply, so this should be set to 0 or 1 for top of the hour? I thought it was a time interval.
The behavior that I am looking for is to check weather.forecast_home_hourly at some point every hour, turn on my smart plug when temperature goes bellow 36° and turn off the plug when it goes above 35 °.
Is there a better attribute and condition that I should use instead?
Thanks again!
Thank you for the responce.
Pardon my question, but what does the backslash indicate?
For weather.forecast_home_hourly entity? Its quite extensive, but here is a snip. Or maybe I am not understanding what you are asking?
So I originally did all of these setting in the GUI and not YAML, so these were added in by the GUI. Is it ok to edit that out then or will it mess anything up?
Thanks again!
Home Assistant’s automation system is based on events, it is rare for Time Pattern triggers to be necessary. Instead of checking multiple times an hour, use a Numeric State trigger to listen for the event of the temperature crossing you desired threshold.
triggers:
  - trigger: numeric_state
    below: 36
conditions: []
actions:
  - action: switch.turn_on
mode: single
Time Pattern trigger docs see the example labelled automation_3.
Excellent, I will try that out when I get home.
Thank you.
