I have created an addon for TriliumNext Notes, the successor of Trilium, which is in maintenance mode since a while.
This is my first addon and I am not a dev, so if there is anything I did badly wrong, please tell me ![]()
Currently the startup takes quite long and I have no idea if this is a config fault on my side.
It was not always like this but I could not find out why. ![]()
Installation
Add repository to your Home Assistant addon repositories:
- Click Add
Find the “TriliumNext Notes” addon and install it.
Start the addon.
Initial Configuration
When running for the first time, the stup will start. Please note:
Important: During initial setup, TriliumNext Notes will display the IP address and port of Home Assistant. This is normal behavior caused by Home Assistant’s ingress system.
Ignore the displayed URL and instead use the Home Assistant interface to access TriliumNext Notes (via the addon or sidebar).
Create a user for and set a secure password.
Configuration Options
| Option | Description | Default |
timezone |
Timezone for the addon | Europe/Berlin |
log_level |
Log level (trace/debug/info/warning/error) | info |
https_only |
Force HTTPS connections only | false |
I hope you like it!
Best regards
Hyper
