Trim an trigger_id in automation and use that as an input value help
so i am trying to usethis simple automation, but as you guess, i cant get it to work.
service: climate.set_temperature
  temperature: states(input_number.home_{{ trigger.entity_id[8:] }} | float)
  entity_id: "{{ trigger.entity_id }}"
for setting the temperature. i need to get the trigger.entity.id (which i can get cause it works for target)
but for the value i needs to trim the first 8 charachters of the trigger.entity_id.Do a joing with a string and use that string to get the state…
trigger.entity_id = climate.living_room_trv
input_number.home_living_room_trv exists (and has a state of 19.0)
This is to make the automation work for all the climate entities. Otherwise i have to add another if/then everPreformatted texty time a new climate entity arrives.
(I know i still have to declare the matching input variable)
Try this:
temperature: "{{ states('input_number.home_' ~ trigger.to_state.object_id) | float(0) }}"
By way of explanation it concatenates (~) the string ‘input_number.home_’ with the object_id of the entity that triggered the automation.
entity_id = domain.object_id
trigger.to_state.domain = climate
trigger.to_state.object_id = living_room_trv
Works perfectly your solution.
and for the ones that need more string manipulation…you can also app python trunctating.
Like this also worls
metadata: {}
  temperature: "{{ states('input_number.home_' ~ trigger.entity_id[8:]) | float(0) }}"
But yours is cleaner for sure, using actial HA variables in stead of cutting them together lol :smiley:
