Tronbyt Server HA Addon
Has anyone successfully run the Tronbyt Server GitHub - tronbyt/server: Manage your apps on your Tronbyt (flashed Tidbyt) completely locally without relying on the backend servers operated by Tidbyt. project as a Home Assistant add-on? or is it possible?
I’m interested in integrating it with Home Assistant, but I’m not sure if it’s compatible as an add-on out of the box, or if I need to wrap it in a custom Docker container. Any tips or examples would be greatly appreciated!
found anyhting? otherwise I would start working in this area
no, i tried somthing with ai but not good at all
