iHege
(Hege Helleland)
April 5, 2022, 9:02pm
1
I installed this earlier and it works perfectly, but the config file changed when I installed it on another system now.
this is the only thing that is in configuration and I cant make it work
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: ‘-d -d’
log: false
mqtt: {}
serial: {}
someone has an idea?
I tried to set user, password and port. but on mine it looks completely different
socat:
enabled: false
options: ‘-d -d’
log: false
mqtt:
base_topic: zigbee2mqtt
user: MQTT
password:
serial:
port: /dev/ttyUSB0
external_converters:
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist:
availability_passlist:
device_options: {}
blocklist:
passlist:
queue: {}
frontend:
port: 8099
experimental: {}
availability: false
I even reinstalled a brand new home assistant, but its the same.
nickrout
(Nick Rout)
April 5, 2022, 9:23pm
2
You have given no useful info like ha installation method, z2m installation method, versions etc etc.
However if you are using the addon for z2m the update to 1.25 introduced a new configuration details.
## 1.25.0-1
- Updated Zigbee2MQTT to version [`1.25.0`](https://github.com/Koenkk/zigbee2mqtt/releases/tag/1.25.0)
- ⚠️ **Breaking changes**
- Most Zigbee2MQTT configuration is now done in Zigbee2MQTT directly
(either via the UI or by modifying the configuration file, usually
`/config/zigbee2mqtt/configuration.yaml`, directly).
As Zigbee2MQTT won't start with an [MQTT server](https://www.zigbee2mqtt.io/guide/configuration/mqtt.html)
or [serial adapter](https://www.zigbee2mqtt.io/guide/configuration/adapter-settings.html)
you must configure these through the add-on configuration page before you
can start Zigbee2MQTT for the first time.
Existing installations should be able to safely remove the Zigbee2MQTT
configuration from the add-on configuration as these values should have
already been persisted to the configuration file.
## 1.24.0-1
- Updated Zigbee2MQTT to version [`1.24.0`](https://github.com/Koenkk/zigbee2mqtt/releases/tag/1.24.0)
## 1.23.0-1
This file has been truncated. show original
iHege
(Hege Helleland)
April 6, 2022, 5:18am
3
It was the new versjon for zigbee2mqtt. 1.25
I have that on mine to but mine still works. I followed a guide on YouTube to install it and its not the same…
Is There a guide for the new update?
Hege Helleland
nickrout
(Nick Rout)
April 6, 2022, 5:20am
4
If you followed some guide on youtube, anyones guess what you did wrong.
Have a read here , maybe will help you ?
