so my configuration.yaml looks like this. when I go to "check config I get the following error
nvalid config for [light]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 14). Please check the docs at https://home-assistant.io/components/light/
if i go #light: !include lights.yaml
then everything is good, no errors
any ideas and what the issue is?
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: xxxxxxxx
longitude: xxxxxxxxx
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 718
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/Edmonton
customize: !include customize.yaml
secrets: !include secrets.yaml
group: !include groups.yaml
script: !include scripts.yaml
device_tracker: !include device_tracker.yaml
switch: !include switches.yaml
sensor: !include sensors.yaml
this is what I have so far in my lights.yaml file.
because of the error I #light: !include lights.yaml
and moved it back to my configuration.yaml file.
I should note that since the update to 77.3 the limitlessly no longer works for some reason.
when you !include yaml files you shouldn’t put the domain in the !include file. It’s already there from the include statememt. So take “light:” out of the lights.yaml file. But leave the 2 spaces before “- platform:”
next, and I’m not sure this is a real problem, but it looks like you have an extra space in your “platform:” definition line between “platform:” and 'limitlessled". try taking that out. there should only be one space between them.
A million thanks, i knew it was probably a can’t see the forest for the trees type thing.
Removing “light” from the lights.yaml solved my little include issue.
you’re also right about there being an extra space between platform: and limitlessled
i removed it, but alas still no luck.
someone needs to put out a “home assistant for dummies” book, for me. lol
