Trouble Adding SMA inverters Yaml presented unexpected errors
Guys could I get a North on where is this going wrong, newbie here, got 2 Error configuraron invalids :
Currenty I get 2 errors:
Error loading /config/configuration.yaml: while parsing a block mapping in “/config/configuration.yaml”, line 21, column 5 expected , but found ‘’ in “/config/configuration.yaml”, line 27, column 9
Also I followed this tutorial for adding the SMA inverters integration:
My Config.yaml file:
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
Text to speech
tts:
  • platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
zwave:
usb_path: /dev/ttyUSB0
usb_path: /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_81300513-if00-port0
zha:
usb_path: /dev/ttyUSB1
database_path: /config/zigbee.db
#attempt adding inverter 1 SMA Solar SMA1990060623
# Example configuration.yaml entry (http)
- platform: sma
host: 192.168.1.221
password: PRXTAUWSEA3H7AX9
sensors:
- current_consumption
- total_consumption
- pv_power
- total_yield
- pv_gen_meter
- daily_yield
- total_consumption
- grid_power_supplied
- grid_power_absorbed
- grid_total_yield
- grid_total_absorbed
- grid_power
- frequency
- voltage_l1
- voltage_l2
- voltage_l2
- status
#/attempt adding inverter 1 SMA Solar SMA1990060623
#attempt adding inverter 2 SMA Solar SMA1990079781
- platform: sma
host: 192.168.1.222
password: 372HXLXPTCMDVSLJ
sensors:
- total_consumption
- pv_power
- total_yield
- pv_gen_meter
- daily_yield
- total_consumption
- grid_total_yield
- grid_power
- frequency
- voltage_l1
- voltage_l2
- voltage_l2
- status
#/attempt adding inverter 2 SMA Solar SMA1990079781
Thanks in Advance!
Aaron!
YAML Flie:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
zwave:
#   usb_path: /dev/ttyUSB0
zha:
         - platform: sma
            host: 192.168.1.221
            sensors:
      - total_consumption
      - pv_power
      - total_yield
      - pv_gen_meter
      - daily_yield
      - total_consumption
      - grid_total_yield
        - grid_power
        - frequency
        - voltage_l1
        - voltage_l2
        - voltage_l2
        - status
         - platform: sma
            host: 192.168.1.222
            sensors:
      - total_consumption
      - pv_power
      - total_yield
      - pv_gen_meter
      - daily_yield
      - total_consumption
      - grid_total_yield
        - grid_power
        - frequency
        - voltage_l1
        - voltage_l2
        - voltage_l2
        - status
