Trouble calling homeassistant service from esphome
Hi everyone, long time home assistant tinkerer, new to esphome.
I’m 99% this is just a formatting/ YAML issue on my part but I cannot get it to work for the life of me.
I have a rotary encoder hooked to a D1 mini.
The following code works exactly as intended:
  - platform: rotary_encoder
    pin_a: D3
    pin_b: D2
    on_clockwise:
     - logger.log: "Turned Clockwise"
    on_anticlockwise:
     - logger.log: "Turned Anticlockwise"
This shows events being logged so I know the hardware and basic config are working.
If I call the service below in developer tools it works as expected:
service: light.turn_on
  brightness_step_pct: 10
  entity_id: light.office
So far so good.
But if I try to put it all together like this it doesn’t work:
    pin_a: D3
    pin_b: D2
    on_clockwise:
     - homeassistant.service:
The editor in HA doesn’t show any error but when I try to upload it I get the following message:
mapping values are not allowed here
in “/config/esphome/esphome-test-1.yaml”, line 86, column 15:
I’ve googled the error and not got anywhere, if anyone can point me in the right direction I’d be very grateful.
Think you data: is too far to the right. 2 spaces left…
Getting there now :slight_smile:
That resolved the first problem.
It also turns out that homeassistant.service doesn’t support “target” so the entity had to go in to the main part of data.
Working code below:
    pin_a: D3
    pin_b: D2
    on_clockwise:
            brightness_step_pct: "10"
    on_anticlockwise:
            brightness_step_pct: "-10"
