Trouble getting google assistant addon to work
I am trying to set up the google assistant addon so that I may use my raspi as a google home, but I am having issues setting it up as there is little documentation on how to do so. I followed the outdated steps that it links to in the description, and have stuck the json file in my shares folder, and once I click on start, I get to the “get token” page, get it, stick it in, and now I’m left with this error after I hit the okay button:
File “/usr/local/lib/python3.5/dist-packages/cherrypy/_cprequest.py”, line 631, in respond
self._do_respond(path_info)
File “/usr/local/lib/python3.5/dist-packages/cherrypy/_cprequest.py”, line 690, in _do_respond
response.body = self.handler()
File “/usr/local/lib/python3.5/dist-packages/cherrypy/lib/encoding.py”, line 221, in call
self.body = self.oldhandler(*args, **kwargs)
File “/usr/local/lib/python3.5/dist-packages/cherrypy/_cpdispatch.py”, line 60, in call
return self.callable(*self.args, **self.kwargs)
File “/hassio_oauth.py”, line 46, in token
self.oauth2.fetch_token(self.user_data[‘token_uri’], client_secret=self.user_data[‘client_secret’], code=token)
File “/usr/local/lib/python3.5/dist-packages/requests_oauthlib/oauth2_session.py”, line 244, in fetch_token
self._client.parse_request_body_response(r.text, scope=self.scope)
File “/usr/local/lib/python3.5/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py”, line 408, in parse_request_body_response
self.token = parse_token_response(body, scope=scope)
File “/usr/local/lib/python3.5/dist-packages/oauthlib/oauth2/rfc6749/parameters.py”, line 379, in parse_token_response
validate_token_parameters(params)
File “/usr/local/lib/python3.5/dist-packages/oauthlib/oauth2/rfc6749/parameters.py”, line 386, in validate_token_parameters
raise_from_error(params.get(‘error’), params)
File “/usr/local/lib/python3.5/dist-packages/oauthlib/oauth2/rfc6749/errors.py”, line 415, in raise_from_error
raise cls(**kwargs)
oauthlib.oauth2.rfc6749.errors.InvalidGrantError: (invalid_grant) Bad Request
My addon configuration looks like this:
I could not find any reference anywhere to the model_id so I took a guess from instructions on a google developer page
HI @Palmer_Duckworth - were you able to solve this?
I’m facing the same issue.
