Hi all.
I’m quite new on esphome. Still learning and try to understand how all works.
Everything was going fine, until now. I need some help.
I’m playing with a ESP32_CAM. It’s already working, but still need some tuning.
But what I want to do is make a card on HomeAssistant to set some parameters of the camera.
I set brightness, saturation and contrast already, making globals and getting the values from homeassistant. This way:
globals:
- id: brightness_atual
type: int
initial_value: "0"
- id: contraste_atual
type: int
initial_value: "0"
- id: saturacao_atual
type: int
initial_value: "0"
- platform: homeassistant
entity_id: input_number.camera_aquario_sala_brightness
on_value:
then:
if:
condition:
lambda: 'return id(brightness_atual) != int(x);'
then:
- logger.log:
level: INFO
format: 'Mudança no Brightness : de %d para %d'
args: ['id(brightness_atual)', 'int(x)']
- globals.set:
value: !lambda 'return int(x);'
- lambda: |-
id(camera).set_brightness(x);
entity_id: input_number.camera_aquario_sala_contraste
on_value:
then:
if:
condition:
lambda: 'return id(contraste_atual) != int(x);'
then:
- logger.log:
level: INFO
format: 'Mudança no Contraste : de %d para %d'
args: ['id(contraste_atual)', 'int(x)']
- globals.set:
- lambda: |-
id(camera).set_contrast(x);
entity_id: input_number.camera_aquario_sala_saturacao
on_value:
then:
if:
condition:
lambda: 'return id(saturacao_atual) != int(x);'
then:
- logger.log:
level: INFO
format: 'Mudança na Saturacao_atual : de %d para %d'
args: ['id(saturacao_atual)', 'int(x)']
- globals.set:
- lambda: |-
id(camera).set_saturation(x);
This way, I can set thos adjustments directly from HA to reflect on the fly.
But Now, I’d like to also change resolution, whitout having to compile a new code in esphome.
So I did the same thing, adding:
- id: resolucao_atual
type: std::string
initial_value: '"800x600"'
entity_id: input_select.resolucao_da_camera_aquario_sala
on_value:
then:
if:
condition:
lambda: 'return id(resolucao_atual) != x.c_str();'
then:
- logger.log:
level: INFO
format: 'Mudança na Resolução : de %s para %s'
args: ['id(resolucao_atual)', 'x']
- globals.set:
value: !lambda 'return x;'
I know the resolution cannot be changed on the fly, need a restart. But my intention here is set the resolution I want and push a button to restart ESPHOME device and apply the new resolution.
But here starts my problems:
This way I get a compiler errors about the type of my global variable and the X value on the lambda function:
/config/camera-aquario-sala.yaml:156:44: error: request for member 'c_str' in 'x', which is of non-class type 'float'
I have tried to remove the .c_str() from x, and algo got erros.
/config/camera-aquario-sala.yaml:156:39: error: no match for 'operator!=' (operand types are 'std::__cxx11::basic_string<char>' and 'float')
lambda: 'return id(resolucao_atual) != x;'
It gives me Tons of warnings and also the following error:
src/esphome/core/automation.h:33:46: error: no matching function for call to 'std::function<std::__cxx11::basic_string<char>(float)>::function(setup()::<lambda(float)>&)'
TemplatableValue(F f) : type_(LAMBDA), f_(f) {}
I have no clue whats wrong.
