Trouble pairing an Ikea driver via ZHA
I’ve having a few issues pairing a Tradfri 10W Driver to my zigbee network.
  • I’ve recently done away with using hubs and connected everything to my server running HAOS in a Virtualbox VM.
  • HA can see the dongle, I’ve paired 22 other devices, and they all work fine.
  • Since having the issue with this driver, I’ve paired other zigbee devices without issue
  • Theres other zigbee router devices within range, as well as the hub (about 5 meters away through a studwall)
I have 2 Ikea Tradfri drivers in my kitchen for the cabinet underlights. I reset them using the pin-hole button for 5-10 seconds as the manual/online help suggests
they flashed, restarted, and after a bit of off and on, resetting a few times, then leaving it powered off and coming back a few hours later, one paired. The other one after several days of trying, leaving it off for long periods.
The ZHA log shows no attempt to join the network, only the other driver sending normal traffic out.
Unsure why this one won’t pair, any help would be appreciated
Click the reset button 4 times.
