I can’t get either of my Somfy RTS blinds paired with a new RFLink device, and am hoping someone can help me please.
I’ve successfully programmed the Arduino with the latest RFLink firmware (R48).
When I use either of my existing single channel Somfy remotes, I see the commands appear on the RFLink Loader serial console:
20;13;RTS;ID=a0002c;SWITCH=01;CMD=UP;
20;14;RTS;ID=a0002c;SWITCH=01;CMD=DOWN;
This makes me think the RFLink is communicating (RX at least).
But no matter what I try, I can’t seem to pair the RFLink to either of the blinds.
I press the program button on the back of the Somfy remote. The blind jiggles up & down as expected. I then send the PAIR command, which results in an OK message:
10;RTS;0F0F0F;0412;1;PAIR;
20;0D;OK;
But the blind does NOT jiggle up & down at this point, like I believe it should to confirm successful pairing.
I see the new entry listed with the RTSSHOW command:
10;RTSSHOW;
RTS Record: 0 Address: FFFFFF RC: FFFF
RTS Record: 1 Address: 0F0F0F RC: 0412
RTS Record: 2 Address: FFFFFF RC: FFFF
RTS Record: 3 Address: 02FFFF RC: 0414
RTS Record: 4 Address: FFFFFF RC: FFFF
RTS Record: 5 Address: FFFFFF RC: FFFF
RTS Record: 6 Address: FFFFFF RC: FFFF
RTS Record: 7 Address: FFFFFF RC: FFFF
RTS Record: 8 Address: FFFFFF RC: FFFF
RTS Record: 9 Address: FFFFFF RC: FFFF
RTS Record: 10 Address: FFFFFF RC: FFFF
RTS Record: 11 Address: FFFFFF RC: FFFF
RTS Record: 12 Address: FFFFFF RC: FFFF
RTS Record: 13 Address: FFFFFF RC: FFFF
RTS Record: 14 Address: FFFFFF RC: FFFF
RTS Record: 15 Address: FFFFFF RC: FFFF
I then try to move the blinds with the UP and DOWN commands, which all result in an OK response after a short delay, yet the blinds fail to move:
10;RTS;0F0F0F;0;DOWN;
20;8B;OK;
10;RTS;0F0F0F;0;UP;
20;8C;OK;
10;RTS;02FFFF;0;DOWN;
20;8D;OK;
This behaviour is the same for both blinds, using each of their own single-channel remotes.
Can anyone help suggest what is going wrong please?
Thanks,
Olie
