I’ve been running HA for months now not still consider myself noob. I’m running HA on Raspberry pi 4 and using the internal Bluetooth adapter. I just disabled it so I could connect to a Bluetooth device with my phone. Not sure if that was the right way to do it. When i went back to renable it it no longer shows up in Devices tab. When i try to add the integration i get “No unconfigured adapters”
Not sure how to do that, but just wanted to say you are likely to get better performance with most uses if you get an esp32 device and program up a Bluetooth proxy device with ESPHome.
