Folks, I’m trying to control the RGB led on a ZW117 Aeotec / AEON Labs Range Extender 6 device (to use as a visual indicator for important notifications, etc).
I can change the LED color via HA UI normally (it shows the color picker and everything), but I can’t figure out how to change it via automation / script.
I tried using the action “Setting a value of a Z-Wave Value”, with command class Color Switch
, and all possible combinations of property / property key / end point, without success (see example below). I always get an error like Node(node_id=9) - NotFoundError: Value 9-51-0-33-0 not found on node Node(node_id=9)
Also tried with command class “Configuration”, but same error.
I don’t have much experience with HA, so would appreciate any tips on how to set a custom Z-Wave parameter, or how to begin troubleshooting.
This is the device, and here’s the documentation. Below you have the Z-Wave debug logs for color switch event done manually through the UI (indentation added).
Thank you!
2023-05-21 18:36:58.615 DEBUG (MainThread) [zwave_js_server] Publishing message:
'command': 'node.set_value',
'messageId': 'aa04ce5893034a149fd8b969897542c1',
'nodeId': 9,
'options': {'transitionDuration': 'default'},
'value': {'blue': 36, 'green': 255, 'red': 145},
'valueId': {'commandClass': 51, 'endpoint': 0, 'property': 'targetColor'}
2023-05-21 18:36:58.763 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='
"type":"event", "event": {
"source":"node",
"event":"value updated",
"nodeId":9,
"args":{
"commandClassName":"Color Switch",
"commandClass":51,
"property":"currentColor",
"propertyKey":2,
"endpoint":0,
"newValue":145,
"prevValue":255,
"propertyName":"currentColor",
"propertyKeyName":"Red"
}', extra='')
2023-05-21 18:36:58.764 DEBUG (MainThread) [homeassistant.components.zwave_js] [light.range_extender_aeotec_6] Value currentColor/Red changed to: 145
2023-05-21 18:36:58.764 DEBUG (MainThread) [zwave_js_server] Received message:
"type":"event",
"event":{
"source":"node",
"nodeId":9,
"args":{
"commandClass":51,
"propertyKey":3,
"endpoint":0,
"newValue":255,
"prevValue":0,
propertyKeyName":"Green"
}', extra='')
2023-05-21 18:36:58.764 DEBUG (MainThread) [homeassistant.components.zwave_js] [light.range_extender_aeotec_6] Value currentColor/Green changed to: 255
"type":"event",
"event":{
"source":"node",
"nodeId":9,
"args":{
"commandClass":51,
"propertyKey":4,
"endpoint":0,
"newValue":36,
"prevValue":0,
"propertyKeyName":"Blue"
}', extra='')
2023-05-21 18:36:58.765 DEBUG (MainThread) [homeassistant.components.zwave_js] [light.range_extender_aeotec_6] Value currentColor/Blue changed to: 36
2023-05-21 18:36:58.765 DEBUG (MainThread) [zwave_js_server] Received message:
"type":"event",
"event":{
"source":"node",
"nodeId":9,
"args":{
"commandClass":51,
"endpoint":0,
"newValue":{"red":145,"green":255,"blue":36},
"prevValue":{"red":145,"green":255,"blue":36},
}', extra='')
2023-05-21 18:36:58.765 DEBUG (MainThread) [homeassistant.components.zwave_js] [light.range_extender_aeotec_6] Value currentColor/None changed to: {'red': 145, 'green': 255, 'blue': 36}
2023-05-21 18:36:58.767 DEBUG (MainThread) [zwave_js_server] Received message:
"type":"event",
"event":{
"source":"node",
"nodeId":9,
"args":{
"commandClass":51,
"property":"targetColor",
"endpoint":0,
"propertyName":"targetColor"
}', extra='')
2023-05-21 18:36:58.768 DEBUG (MainThread) [homeassistant.components.zwave_js] [light.range_extender_aeotec_6] Value targetColor/None changed to: {'red': 145, 'green': 255, 'blue': 36}
2023-05-21 18:36:58.768 DEBUG (MainThread) [zwave_js_server] Received message:
"type":"event",
"event":{
"source":"node",
"nodeId":9,
"args":{
"commandClass":51,
"property":"hexColor",
"endpoint":0,
"newValue":"91ff24",
"prevValue":"ff0000",
"propertyName":"hexColor"
}', extra='')
"type":"result",
"success":true,
"messageId":"aa04ce5893034a149fd8b969897542c1",
"result":{"success":true}
}', extra='')
