I get the “port 10001 already in use” message when I try to run it for the first time. How can I get around this?
I should add that pretty much all of the ports it wants are already in use. Can I manually point all of them to different ports or must they be the default ones to work?
Because when I change every port so the conflicts stop, I can’t load the web ui. It just waits forever on a blank page and then times out.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: UniFi Network Application
Manage your UniFi network using a web browser
Add-on version: 2.1.0
You are running the latest version of this add-on.
System: null (amd64 / qemux86-64)
Home Assistant Core: 2021.5.1
Home Assistant Supervisor: 2022.03.5
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] unifi.sh: executing...
[cont-init.d] unifi.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[09:53:08] INFO: Now starting the UniFi Network Application...
[09:53:08] INFO: Note: No add-on specific logs beyond this point.
