First one:
Logger: homeassistant.helpers.template
Source: helpers/template.py:2652
First occurred: July 9, 2024 at 13:00:00 (13 occurrences)
Last logged: 14:18:09
Template variable error: 'dict object' has no attribute 'from_state' when rendering 'Feuchtigkeit ist zu hoch. Lüften. Auslöser: {{ trigger.from_state.attributes.friendly_name }}. Absolute Luftfeuchtigkeit Innen {{ inside }}, Außen {{ outside }}.'
Template variable error: 'config' is undefined when rendering 'template - trigger: - platform: homeassistant event: start - platform: state entity_id: - sensor.tuyathsensor2_temperature - sensor.tuyathsensor2_humidity - weather.forecast_home action: - variables: config: inside: temperature: "{{ states('sensor.tuyathsensor2_temperature') }}" humidity: "{{ states('sensor.tuyathsensor2_humidity') }}" outside: temperature: "{{ state_attr('weather.forecast_home', 'temperature') }}" humidity: "{{ state_attr('weather.forecast_home', 'humidity') }}" calculation: > {% set ns = namespace(items=[]) %} {% for location, item in config.items() %} {% set calculation = (e ** ((17.67 * item.temperature) / (243.5 + item.temperature)) * 6.112 * item.humidity * 2.1674 ) / (273.15 + item.temperature) %} {% set ns.items = ns.items + [ (location, calculation) ] %} {% endfor %} {{ dict.from_keys(ns.items) }} offset: "{{ calculation.inside - calculation.outside }}" sensor: - name: .... state: "{{ iif(calculation.inside < calculation.outside, 'Lüften', 'Schliessen') }}"'
Template variable error: 'config' is undefined when rendering 'template - trigger: - platform: homeassistant event: start - platform: state entity_id: - sensor.tuyathsensor2_temperature - sensor.tuyathsensor2_humidity - weather.forecast_home action: - variables: config: inside: temperature: "{{ states('sensor.tuyathsensor2_temperature') }}" humidity: "{{ states('sensor.tuyathsensor2_humidity') }}" outside: temperature: "{{ state_attr('weather.forecast_home', 'temperature') }}" humidity: "{{ state_attr('weather.forecast_home', 'humidity') }}" calculation: > {% set ns = namespace(items=[]) %} {% for location, item in config.items() %} {% set calculation = (e ** ((17.67 * item.temperature) / (243.5 + item.temperature)) * 6.112 * item.humidity * 2.1674 ) / (273.15 + item.temperature) %} {% set ns.items = ns.items + [ (location, calculation) ] %} {% endfor %} {{ dict.from_keys(ns.items) }} offset: "{{ calculation.inside - calculation.outside }}" sensor: - name: Test state: "{{ if (calculation.inside < calculation.outside, 'Lüften', 'Schliessen') }}"'
Template variable error: 'config' is undefined when rendering 'variables: config: inside: temperature: "{{ states('sensor.tuyathsensor2_temperature') }}" humidity: "{{ states('sensor.tuyathsensor2_humidity') }}" outside: temperature: "{{ state_attr('weather.forecast_home','temperature') }}" humidity: "{{ state_attr('weather.forecast_home', 'humidity') }}" calculation: > {% set ns = namespace(items=[]) %} {% for location, item in config.items() %} {% set calculation = (e ** ((17.67 * item.temperature) / (243.5 + item.temperature)) * 6.112 * item.humidity * 2.1674 ) / (273.15 + item.temperature) %} {% set ns.items = ns.items + [ (location, calculation) ] %} {% endfor %} {{ dict.from_keys(ns.items) }} offset: "{{ calculation.inside - calculation.outside }}" state: "{{ if (calculation.inside < calculation.outside, 'Lüften', 'Schliessen') }}"'
Template variable error: 'config' is undefined when rendering 'template - trigger: - platform: homeassistant event: start - platform: state entity_id: - sensor.tuyathsensor2_temperature - sensor.tuyathsensor2_humidity - weather.forecast_home action: - variables: config: inside: temperature: "{{ states('sensor.tuyathsensor2_temperature') }}" humidity: "{{ states('sensor.tuyathsensor2_humidity') }}" outside: temperature: "{{ state_attr('weather.forecast_home', 'temperature') }}" humidity: "{{ state_attr('weather.forecast_home', 'humidity') }}" calculation: > {% set ns = namespace(items=[]) %} {% for location, item in config.items() %} {% set calculation = (e ** ((17.67 * item.temperature) / (243.5 + item.temperature)) * 6.112 * item.humidity * 2.1674 ) / (273.15 + item.temperature) %} {% set ns.items = ns.items + [ (location, calculation) ] %} {% endfor %} {{ dict.from_keys(ns.items) }} offset: "{{ calculation.inside - calculation.outside }}" sensor: - name: .... state: "{{ if(calculation.inside < calculation.outside, 'Lüften', 'Schliessen') }}"'
Second:
Logger: homeassistant.components.template.template_entity
Source: components/template/template_entity.py:197
integration: Template
First occurred: July 6, 2024 at 22:35:47 (158 occurrences)
TemplateError('UndefinedError: 'config' is undefined') while processing template 'Template<template=(-variables: config: inside: temperature: "{{ states('sensor.tuyathsensor2_temperature') }}" humidity: "{{ states('sensor.tuyathsensor2_humidity') }}" outside: temperature: "{{ state_attr('weather.forecast_home', 'temperature') }}" humidity: "{{ state_attr('weather.forecast_home', 'humidity') }}" calculation: > {% set ns = namespace(items=[]) %} {% for location, item in config.items() %} {% set calculation = (e ** ((17.67 * item.temperature) / (243.5 + item.temperature)) * 6.112 * item.humidity * 2.1674 ) / (273.15 + item.temperature) %} {% set ns.items = ns.items + [ (location, calculation) ] %} {% endfor %} {{ dict.from_keys(ns.items) }} offset: "{{ calculation.inside - calculation.outside }}" sensor: - name: Test state: "{{ if(calculation.inside < calculation.outside, 'Lüften', 'Schliessen') }}") renders=4>' for attribute '_attr_native_value' in entity 'None'
TemplateError('UndefinedError: 'config' is undefined') while processing template 'Template<template=(variables: config: inside: temperature: "{{ states('sensor.tuyathsensor2_temperature') }}" humidity: "{{ states('sensor.tuyathsensor2_humidity') }}" outside: temperature: "{{ state_attr('weather.forecast_home', 'temperature') }}" humidity: "{{ state_attr('weather.forecast_home', 'humidity') }}" calculation: > {% set ns = namespace(items=[]) %} {% for location, item in config.items() %} {% set calculation = (e ** ((17.67 * item.temperature) / (243.5 + item.temperature)) * 6.112 * item.humidity * 2.1674 ) / (273.15 + item.temperature) %} {% set ns.items = ns.items + [ (location, calculation) ] %} {% endfor %} {{ dict.from_keys(ns.items) }} offset: "{{ calculation.inside - calculation.outside }}" sensor: - name: Test state: "{{ if(calculation.inside < calculation.outside, 'Lüften', 'Schliessen') }}") renders=4>' for attribute '_attr_native_value' in entity 'None'
TemplateError('UndefinedError: 'config' is undefined') while processing template 'Template<template=(template - trigger: - platform: homeassistant event: start - platform: state entity_id: - sensor.tuyathsensor2_temperature - sensor.tuyathsensor2_humidity - weather.forecast_home action: - variables: config: inside: temperature: "{{ states('sensor.tuyathsensor2_temperature') }}" humidity: "{{ states('sensor.tuyathsensor2_humidity') }}" outside: temperature: "{{ state_attr('weather.forecast_home', 'temperature') }}" humidity: "{{ state_attr('weather.forecast_home', 'humidity') }}" calculation: > {% set ns = namespace(items=[]) %} {% for location, item in config.items() %} {% set calculation = (e ** ((17.67 * item.temperature) / (243.5 + item.temperature)) * 6.112 * item.humidity * 2.1674 ) / (273.15 + item.temperature) %} {% set ns.items = ns.items + [ (location, calculation) ] %} {% endfor %} {{ dict.from_keys(ns.items) }} offset: "{{ calculation.inside - calculation.outside }}" sensor: - name: .... state: "{{ iif(calculation.inside < calculation.outside, 'Lüften', 'Schliessen') }}") renders=4>' for attribute '_attr_native_value' in entity 'None'
TemplateError('UndefinedError: 'config' is undefined') while processing template 'Template<template=(template - trigger: - platform: homeassistant event: start - platform: state entity_id: - sensor.tuyathsensor2_temperature - sensor.tuyathsensor2_humidity - weather.forecast_home action: - variables: config: inside: temperature: "{{ states('sensor.tuyathsensor2_temperature') }}" humidity: "{{ states('sensor.tuyathsensor2_humidity') }}" outside: temperature: "{{ state_attr('weather.forecast_home', 'temperature') }}" humidity: "{{ state_attr('weather.forecast_home', 'humidity') }}" calculation: > {% set ns = namespace(items=[]) %} {% for location, item in config.items() %} {% set calculation = (e ** ((17.67 * item.temperature) / (243.5 + item.temperature)) * 6.112 * item.humidity * 2.1674 ) / (273.15 + item.temperature) %} {% set ns.items = ns.items + [ (location, calculation) ] %} {% endfor %} {{ dict.from_keys(ns.items) }} offset: "{{ calculation.inside - calculation.outside }}" sensor: - name: .... state: "{{ if(calculation.inside < calculation.outside, 'Lüften', 'Schliessen') }}") renders=4>' for attribute '_attr_native_value' in entity 'None'
TemplateError('UndefinedError: 'config' is undefined') while processing template 'Template<template=(template - trigger: - platform: homeassistant event: start - platform: state entity_id: - sensor.tuyathsensor2_temperature - sensor.tuyathsensor2_humidity - weather.forecast_home action: - variables: config: inside: temperature: "{{ states('sensor.tuyathsensor2_temperature') }}" humidity: "{{ states('sensor.tuyathsensor2_humidity') }}" outside: temperature: "{{ state_attr('weather.forecast_home', 'temperature') }}" humidity: "{{ state_attr('weather.forecast_home', 'humidity') }}" calculation: > {% set ns = namespace(items=[]) %} {% for location, item in config.items() %} {% set calculation = (e ** ((17.67 * item.temperature) / (243.5 + item.temperature)) * 6.112 * item.humidity * 2.1674 ) / (273.15 + item.temperature) %} {% set ns.items = ns.items + [ (location, calculation) ] %} {% endfor %} {{ dict.from_keys(ns.items) }} offset: "{{ calculation.inside - calculation.outside }}" sensor: - name: .... state: "{{ if(calculation.inside < calculation.outside, 'Lüften', 'Schliessen') }}") renders=4>' for attribute '_attr_native_value' in entity 'sensor.testtemp'
