TLDR: I had the same issue. My vdisk had enough space, but my data partition was not expanded to utilize that space. I deleted the database file, updated, then expanded the data partition and made sure hassos could read the actual vdisk size.
I was experiencing the same issues and have unsuccessfully tried the same. No joy.
19-02-22 21:28:26 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.88.1
19-02-22 21:30:25 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.88.1
19-02-22 21:30:25 INFO (SyncWorker_4) [hassio.docker.interface] Update Docker homeassistant/qemux86-64-homeassistant:0.87.1 to homeassistant/qemux86-64-homeassistant:0.88.1
19-02-22 21:30:25 INFO (SyncWorker_4) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.88.1.
19-02-22 21:30:33 ERROR (SyncWorker_4) [hassio.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:0.88.1 -> 404 Client Error: Not Found ("no such image: homeassistant/qemux86-64-homeassistant:0.88.1: No such image: homeassistant/qemux86-64-homeassistant:0.88.1").
19-02-22 21:30:33 WARNING (MainThread) [hassio.homeassistant] Home Assistant is already running!
19-02-22 21:30:33 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.88.1
Additionally, pulling new images also rendered 404
19-02-22 22:28:33 INFO (MainThread) [hassio.addons.addon] Create Home Assistant add-on data folder /data/addons/data/a0d7b954_unifi
19-02-22 22:28:33 INFO (SyncWorker_3) [hassio.docker.interface] Pull image hassioaddons/unifi tag 0.7.0.
19-02-22 22:28:51 ERROR (SyncWorker_3) [hassio.docker.interface] Can't install hassioaddons/unifi:0.7.0 -> 404 Client Error: Not Found ("no such image: hassioaddons/unifi:0.7.0: No such image: hassioaddons/unifi:0.7.0").
Furthermore the system seemed to have dropped my ESPHome container and I was unable to communicate with any sonos speakers. I will continue troubleshooting tomorrow.
System Health
System Health
arch |
x86_64 |
dev |
false |
docker |
true |
hassio |
true |
os_name |
Linux |
python_version |
3.6.6 |
timezone |
Europe/Oslo |
version |
0.87.1 |
virtualenv |
false |
Lovelace
mode |
storage |
resources |
1 |
views |
3 |
2019-02-22 23:39:08 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) database or disk is full [SQL: 'DELETE FROM states WHERE states.last_updated < ?'] [parameters: ('2019-02-12 22:38:23.001444',)] (Background on this error at: http://sqlalche.me/e/e3q8)
2019-02-22 23:39:08 WARNING (Recorder) [homeassistant.components.recorder.purge] Error purging history: (sqlite3.OperationalError) database or disk is full [SQL: 'DELETE FROM states WHERE states.last_updated < ?'] [parameters: ('2019-02-12 22:38:23.001444',)] (Background on this error at: http://sqlalche.me/e/e3q8).
I tried deleting home-assistant_v2.db and rebooting the host system which made the system drop all z-wave components. I forced a manual system update from the Hass.io menu which updated my system.
19-02-22 22:49:24 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.88.1
19-02-22 22:49:24 INFO (SyncWorker_3) [hassio.docker.interface] Update Docker homeassistant/qemux86-64-homeassistant:0.87.1 to homeassistant/qemux86-64-homeassistant:0.88.1
19-02-22 22:49:24 INFO (SyncWorker_3) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.88.1.
19-02-22 22:49:57 INFO (SyncWorker_3) [hassio.docker.interface] Tag image homeassistant/qemux86-64-homeassistant with version 0.88.1 as latest
19-02-22 22:49:57 INFO (SyncWorker_3) [hassio.docker.interface] Stop homeassistant/qemux86-64-homeassistant Docker application
19-02-22 22:50:27 INFO (SyncWorker_3) [hassio.docker.interface] Clean homeassistant/qemux86-64-homeassistant Docker application
19-02-22 22:50:27 INFO (SyncWorker_3) [hassio.docker.interface] Cleanup Docker images: ['homeassistant/qemux86-64-homeassistant:0.87.1']
19-02-22 22:50:30 INFO (SyncWorker_2) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.88.1
19-02-22 22:50:40 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-02-22 22:50:40 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.88.1
I was now running 0.88.1 I forced another reboot which seemed to crash the whole VM resulting in a manual hypervisor initiated reset. Once complete, hassio came back online showing version 0.88.1 and all my z-wave devices back in play.
As this was clearly a space issue i put the following into configuration.yaml
- platform: systemmonitor
resources:
- type: disk_free
arg: /home
- type: memory_free
Which didn’t really work at all, but I got the disk_use working, which states usage in percent. Reported percent was 46.1% this was wrong. The hypervisor reported 9% drive usage. It is using 5,55 GB of 61 gb available.
I am guessing my issue has to do with some internal partitioning as i expanded the drive after i experienced these errors. I will continue troubleshooting tomorrow.
Update: I booted GNOME partition editor live CD and expanded the partition containing data successfully. Everything is normal and apparently working for me. I expanded stuff some more since i was already “in there”. Ended up with a 100 gb vdrive and 2.5% current disk usage.
Are you able to verify drive space from within the image @mchiass ? If not, see if you can delete something to free up space and see if it helps? Maybe Ubuntu is reporting same available space as the hypervisor/vdisk?
