Trouble upgrading ESPhome from v 4.1 to 4.2
I run Home Assistant on a rasberry pi 4. I use ESPhome to connect a ratgdo 2.5 w/security 1, garage door controller. I then use the HomeKit bridge add on to control everything in the home app in iOS.
Last weekend ratgdo stopped working. I reflashed the board, and currently have ESPhome 4.1 installed, but the only thing I see in the iOS home app is the door toggle switch and the lock or unlock remote switch. I use to have a light switch and a door button where I could choose open or close. Even though I’ve tried to add the light and door switch they fail to appear.
I’ve tried to upgrade ESPhome to 4.2 (the latest version) but I get the error below.
INFO ESPHome 2025.4.2
INFO Reading configuration /config/esphome/ratgdov25i-86b418.yaml…
INFO Updating https://github.com/ratgdo/esphome-ratgdo@None
INFO Updating https://github.com/ratgdo/esphome-ratgdo@main
INFO Detected timezone ‘America/Toronto’
INFO Generating C++ source…
INFO Compiling app…
Processing ratgdov25i-86b418 (board: d1_mini; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.3.0
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.6
|-- ArduinoJson @ 6.18.5
|-- Secplus @ 1.0.0+sha.f98c322
|-- EspSoftwareSerial @ 8.1.0+sha.57f1aa7
|-- Improv @ 1.2.4
Compiling .pioenvs/ratgdov25i-86b418/src/esphome/components/api/api_connection.cpp.o
xtensa-lx106-elf-g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
*** [.pioenvs/ratgdov25i-86b418/src/esphome/components/api/api_connection.cpp.o] Error 1
========================= [FAILED] Took 65.33 seconds =========================
====== [ERROR] /config/esphome/ratgdov25i-86b418.yaml ======
======================== [SUMMARY] ========================
  • /config/esphome/ratgdov25i-86b418.yaml: FAILED
Thanks for any help!
Hello Steveseg,
Welcome to the HomeAssistyant Forum!
You might want to ask here. There are more expert eyes for this topic.
ESPhome Discord
When I’ve had problems with esphome on rpi4 I uninstall it and reinstall it. It doesnt remove your existing devices yaml.
