so I modded my UPPATVIND with esphome. Everything works perfectly, but I tryed to build an aumation for it. I wish that if it has been working for 30 min, it simply puts it off. Now the trouble it’s that it has 3 speed, so if I’m at speed 3, it only need to press once, but at speed 1 it needs to press 3 times. Also if the press are too quick, it doesn’t seem to work either, hence the delay. My current automation works sometimes, others not most of the time it will click once or twice, so if I’m at speed 3 for example it will close the air purifier, but if I’m at speed 1, it will set it to speed 3, and let it go
How can I make a better automation ?
alias: UPPATVIND Close after 30 min
description: ""
- platform: numeric_state
entity_id:
- sensor.uppatvind_fan_speed_led
for:
hours: 0
minutes: 30
seconds: 0
above: 0
condition: []
- service: button.press
metadata: {}
data: {}
entity_id: button.uppatvind_switch
- delay:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
- if:
- condition: numeric_state
entity_id: sensor.uppatvind_fan_speed_led
above: 0
then:
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
- if:
above: 0
then:
metadata: {}
data: {}
mode: single
