Trouble with Comfoconnect
Hallo
Im new at this - and i am trying to connect my AHU but i get this error:
Invalid config
The following integrations and platforms could not be set up:
Please check your config.
and my configuration.yalm I have this:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
## KAMERAOPSÆTNING
#binary_sensor:
#  - platform: hikvision
#    host: 192.168.1.200
#    port: 80
#    ssl: false
#    username: admin
#    password: 9433
##    customize:
##      motion_1:
##        delay: 30
##      field_detection_2:
##        ignored: true
# VENTILATIONSANLÆG kontakt
comfoconnect:
  host: 192.168.1.193
#  name: ComfoAirQ350
#  pin: 0000
# VENTILATIONSAGGREGAT
  - platform: comfoconnect
    resources:
      - air_flow_exhaust
      - air_flow_supply
      - bypass_state
      - current_humidity
      - current_temperature
      - days_to_replace_filter
      - exhaust_fan_duty
      - exhaust_fan_speed
      - exhaust_humidity
      - exhaust_temperature
      - outside_humidity
      - outside_temperature
      - power_usage
      - supply_fan_duty
      - supply_fan_speed
      - supply_humidity
      - supply_temperature
# REJSEPLANEN
  - platform: rejseplanen
    stop_id: 9755
What is wrong? "Rejseplanen works fine!
