I’m trying to integrate my DD7002B Connector Bridge (for roller blinds) into Home Assistant using the built-in Motionblinds integration.
I successfully discovered the bridge, and the blinds show up in HA.
I retrieved the API key by going into the Connector app → Profile → About → tapping 5 times. The key looks like this format: 27133932-4cea-4a which matches what the docs say.
However, whenever I try to control the blinds I get repeated errors like this in the HA logs:
Received actionResult: ‘AccessToken error’, when sending message:
{‘msgType’: ‘WriteDevice’, ‘mac’: ‘a4cf1288eab40002’, ‘deviceType’: ‘10000000’,
‘AccessToken’: ‘xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx’, ‘msgID’: ‘20250912121907702’,
‘data’: {‘operation’: 5}}
So the blinds are detected but won’t respond to commands.
What I’ve tried:
Resetting HA integration and re-adding the bridge.
Confirmed the hub IP is correct and accessible on my LAN.
Double-checked the app key multiple times (it’s always the same).
Questions:
Has anyone else with the DD7002B seen “AccessToken error” with the Motionblinds integration?
Is there a different way to extract the correct key for this bridge?
Would resetting the bridge and re-pairing help, or is there another step I’m missing?
Any advice or success stories with this model would be much appreciated!
sadly I haven’t gotten a solution, but I’ve got the same issue.
I’ve got a Yooda Smart Home 2 gateway module which communicates with the Connector app.
Connection to the gateway seems to work but not the commands.
Bonsoir, j’ai également la Yooda Smart Home 2. J’arrive a communiquer avec Home assistant avec Motionblinds.
Mais parfois cela ne reponds pas toujours.
En general les volets s’ouvrent , mais ne se ferment pas.
I did an update yesterday night, of the Yooda Smart Home 2. From now, not working anymore:
Enregistreur: motionblinds.motion_blinds
Source: /usr/local/lib/python3.13/site-packages/motionblinds/motion_blinds.py:532
S’est produit pour la première fois: 4 janvier 2026 à 23:21:38 (80 occurrences)
Dernier enregistrement: 18:03:59
