Trouble with getting a boolean from a script in an automation
I have an automation that runs when a sensor is updated. It performs a bunch of analysis and then returns a structure with a scene and a boolean (whether or not to activate the scene).
When I paste my script into the template tool it evaluates, as I expect it to, to:
  "scene": "scene.high_power",
  "update": true
But I can’t get the conditional in my automation to use the value of update.
alias: Power management scenes
description: ""
triggers:
  - trigger: state
    entity_id:
      - sensor.heuristic_power_1000_sec
conditions: []
actions:
  - action: script.scene_selector_script
    metadata: {}
    data: {}
    response_variable: new_scene
  - if:
      - condition: template
        value_template: "{{ new_scene.update }}"
    then:
      - action: scene.turn_on
        metadata: {}
        data: {}
          entity_id: "{{ new_scene.scene }}"
mode: single
When I do a trace, it comes back that the conditional was false
Executed: January 17, 2025 at 1:44:28 PM
if
Result:
result: false
if/condition/0
[If template renders a value equal to true]
Result:
result: false
entities: []
Any ideas what I am doing wrong?
What does the “Changed Variables” section of the trace show for new_scene?
I hadn’t even noticed that feature before, thank you!
Here’s what it says (the state in my house has changed; the conditional is still true, but being evaluated as false)
context:
  parent_id: 01JHTTKG6B9THZ81190RKWVJJR
  user_id: null
new_scene:
  scene: scene.save_power
  update: true
I tend to make sure in cases like this that what I think is happening, is actually happening.
I would cast that as a bool…
        value_template: "{{ new_scene.update | bool }}"
I tried that and now I get this error in my trace:
Error: In 'template' condition: ValueError: Template error: bool got invalid input '' when rendering template '{{ new_scene.update | bool }}' but no default was specified
Am I correct that this makes it look like a scope issue? like my value_template doesn’t know about new_scene?
Interesting, that might be a clue as well.
As a testing step I removed my conditional statement, and the scene was applied as expected.
This isn’t viable as a solution, I still need the conditional, but maybe the information helps?
actions:
    metadata: {}
    data: {}
#  - if:
#      - condition: template
#        value_template: "{{ new_scene.update }}"
#    then:
#      - action: scene.turn_on
#        metadata: {}
#        data: {}
#        target:
#          entity_id: "{{ new_scene.scene }}"
    metadata: {}
    data: {}
Try adding the condition directly to the action block:
actions:
    metadata: {}
    data: {}
    metadata: {}
    data: {}
I gave that a try…
I got the same behavior.
trace results for changed variables from my script:
context:
  parent_id: 01JHV13T569PK5SQGVAPNG00MX
  user_id: null
new_scene:
  update: true
  scene: scene.low_power
And the conditional step
@Sir_Goodenough @Didgeridrew
Thank you both so much for helping me with this. I finally got it working.
I think update must be some kind of reserved keyword or something. I changed the name of the variable from ‘update’ to ‘doit’ and everything started working just as I intended.
context:
  parent_id: 01JHV4JTJJKXVAXY9ZSHH33Z7G
  user_id: null
new_scene:
  doit: 'true'
That is strange, it must be clashing with an underlying Python method… I just checked and it does work if you use bracket notation instead of dot notation as follows:
  - if:
        value_template: "{{ new_scene['update'] }}"
wild, I didn’t even know there was an alternative to the dot notation.
(I’ve only been doing home assistant for about 3 weeks)
