Trouble with hass.io
Hi
I have posted before about network trouble with hass.io. I have now flashed my pi3 with a fresh image. I haven’t done anything with the config files or anything. But I think yr weather is supposed to work out of the box but it doesn’t.
I think there is something wrong with the network inside the docker image… another problem is that the time is wrong with two hours…
2017-09-24 16:58:49 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-09-24 16:58:53 WARNING (MainThread) [homeassistant.components.sensor.yr] Retrying in 15 minutes: [Errno -3] Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:True [Try again]
2017-09-24 17:02:45 WARNING (MainThread) [homeassistant.components.sensor.yr] Retrying in 15 minutes: [Errno -3] Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:True [Try again]
2017-09-24 17:08:02 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py”, line 278, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File “aiohttp/_http_parser.pyx”, line 274, in aiohttp._http_parser.HttpParser.feed_data (aiohttp/_http_parser.c:4364)
aiohttp.http_exceptions.BadStatusLine: invalid HTTP method
Supervisor logs:
Supervisor Logs
starting version 3.2.2
17-09-17 13:49:37 INFO (MainThread) [main] Initialize Hassio setup
17-09-17 13:49:37 INFO (MainThread) [hassio.bootstrap] Create Home-Assistant config folder /data/homeassistant
17-09-17 13:49:37 INFO (MainThread) [hassio.bootstrap] Create hassio ssl folder /data/ssl
17-09-17 13:49:37 INFO (MainThread) [hassio.bootstrap] Create hassio addon data folder /data/addons/data
17-09-17 13:49:37 INFO (MainThread) [hassio.bootstrap] Create hassio addon local repository folder /data/addons/local
17-09-17 13:49:37 INFO (MainThread) [hassio.bootstrap] Create hassio addon git repositories folder /data/addons/git
17-09-17 13:49:37 INFO (MainThread) [hassio.bootstrap] Create hassio temp folder /data/tmp
17-09-17 13:49:37 INFO (MainThread) [hassio.bootstrap] Create hassio backup folder /data/backup
17-09-17 13:49:37 INFO (MainThread) [hassio.bootstrap] Create hassio share folder /data/share
17-09-17 13:49:37 INFO (MainThread) [hassio.dock.network] Can’t find HassIO network, create new network
17-09-17 13:49:38 INFO (MainThread) [main] Run Hassio setup
17-09-17 13:49:38 INFO (SyncWorker_0) [hassio.dock.supervisor] Attach to supervisor homeassistant/armhf-hassio-supervisor with version 0.63
17-09-17 13:49:42 INFO (MainThread) [hassio.host_control] Send ‘info’ to HostControl.
17-09-17 13:49:48 INFO (MainThread) [hassio.host_control] Receive from HostControl: { “type”: “resinos”, “version”: “1.1”, “last_version”: “1.1”, “hostname”: “hassio”, “features”: [“shutdown”, “reboot”, “update”, “hostname”], “os”: “GNU/Linux” }.
17-09-17 13:49:48 INFO (MainThread) [hassio.homeassistant] No HomeAssistant docker homeassistant/raspberrypi3-homeassistant found.
17-09-17 13:49:48 INFO (MainThread) [hassio.homeassistant] Setup HomeAssistant landingpage
17-09-17 13:49:48 INFO (SyncWorker_2) [hassio.dock.interface] Pull image homeassistant/raspberrypi3-homeassistant tag landingpage.
17-09-24 16:49:42 INFO (SyncWorker_2) [hassio.dock.interface] Tag image homeassistant/raspberrypi3-homeassistant with version landingpage as latest
17-09-24 16:49:43 INFO (SyncWorker_5) [hassio.dock.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version landingpage
17-09-24 16:49:43 INFO (MainThread) [hassio.addons.git] Clone addon https://github.com/home-assistant/hassio-addons repository
17-09-24 16:49:50 INFO (MainThread) [hassio.addons] Load addons: 14 all - 14 new - 0 remove
17-09-24 16:49:50 INFO (MainThread) [hassio.addons] Startup initialize run 0 addons
17-09-24 16:49:50 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
17-09-24 16:49:51 INFO (MainThread) [main] Start Hassio
17-09-24 16:49:51 INFO (MainThread) [main] Run Hassio loop
17-09-24 16:49:51 INFO (MainThread) [hassio.addons.git] Pull addon https://github.com/home-assistant/hassio-addons repository
17-09-24 16:49:51 INFO (MainThread) [hassio.dns] Start DNS port forwarding for host add-ons
17-09-24 16:49:51 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-09-24 16:49:55 INFO (MainThread) [hassio.core] Start hassio api on 172.30.32.2
17-09-24 16:49:55 INFO (MainThread) [hassio.addons] Startup system run 0 addons
17-09-24 16:49:55 INFO (MainThread) [hassio.addons] Startup services run 0 addons
17-09-24 16:49:55 INFO (MainThread) [hassio.addons] Startup application run 0 addons
17-09-24 16:49:55 INFO (MainThread) [hassio.homeassistant] Setup HomeAssistant
17-09-24 16:49:55 INFO (SyncWorker_1) [hassio.dock.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.54.
17-09-24 16:49:56 INFO (MainThread) [hassio.addons] Load addons: 14 all - 0 new - 0 remove
17-09-24 16:58:02 INFO (SyncWorker_1) [hassio.dock.interface] Tag image homeassistant/raspberrypi3-homeassistant with version 0.54 as latest
17-09-24 16:58:02 INFO (MainThread) [hassio.homeassistant] HomeAssistant docker now installed
17-09-24 16:58:02 INFO (SyncWorker_6) [hassio.dock.interface] Stop homeassistant/raspberrypi3-homeassistant docker application
17-09-24 16:58:03 INFO (SyncWorker_6) [hassio.dock.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
17-09-24 16:58:05 INFO (SyncWorker_6) [hassio.dock.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.54
17-09-24 16:58:05 INFO (SyncWorker_13) [hassio.dock.interface] Cleanup docker images: [‘homeassistant/raspberrypi3-homeassistant:landingpage’]
17-09-24 17:13:44 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-09-24 17:13:44 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
17-09-24 17:13:44 INFO (MainThread) [hassio.addons.git] Pull addon https://github.com/home-assistant/hassio-addons repository
17-09-24 17:13:44 INFO (MainThread) [hassio.host_control] Send ‘info’ to HostControl.
17-09-24 17:13:49 INFO (MainThread) [hassio.addons] Load addons: 14 all - 0 new - 0 remove
17-09-24 17:13:49 INFO (MainThread) [hassio.host_control] Receive from HostControl: { “type”: “resinos”, “version”: “1.1”, “last_version”: “1.1”, “hostname”: “hassio”, “features”: [“shutdown”, “reboot”, “update”, “hostname”], “os”: “GNU/Linux” }.
