Trouble with RTSP feeds through HAPROXY and vips
I set up RTSP streams from my 3 cameras in uinifi video, so that I can stream them to my home assistant dashboard. I’m running both Home Assistant as well as Unifi Video on a kubernetes cluster, using HAProxy as a go-between to proxy to either host (Unifi video is using node ports, ignore that for now).
Basically, here’s my setup
Host: 192.168.1.20 or .21 (depending on which node UFV is running on
UFV: 10.44.0.42 IP (could change if pod moves/ restarts. unifi video is listening on 7447 for RTSP as well as 31447 for each node (so that traffic to 31447 of either node goes to 7447.
Haproxy: listening on 192.168.1.25 (VIP) and port 7447. This then forwards to 31443 of the hosts (.20 and .21)
Unifi video shows the streams with the containers ip, so something like
rtsp://10.44.0.42:7447/598e978e5d441fb538aff96d_0
If I put this into Home assistant’s camera config, it works and i can see images from the cameras. However, if I change to 192.168.1.25:31447 (so that I go through HAPROXY, and dont need to update the ip every time), i get no video. I originally tried loading 192.168.1.25:7447/598e978e5d441fb538aff96d_0 into vlc, and tada…I get video, which tells me that haproxy works, but for some reason Home Assistant only works with the direct IP. I originally thought this was a Ubiquiti Unifi video problem, but running it through VLC tells me it might be a ffmpeg or HA problem. I’ve tried both using the hosts’s ip 192.168.20:31447, etc, but this also does not work.
Is there something that I’m missing here? VLC works, but ffmpeg/HA doesn’t seem to like going through a proxy.
