Troubleshoot from restore
So since my SD card corrupted and my restore with full home assistant install on rpi3 most of my entities have become completely or randomly unavailable. I only find one error msg in the log and my question is would this error explain the failure of the integrations: This seems to be the pertinent part of the log:
20-08-28 21:28:41 ERROR (MainThread) [supervisor.homeassistant] Error on call http://172.30.32.1:8123/api/config:
20-08-28 21:28:47 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 257:None is not str
20-08-28 21:28:47 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
20-08-28 21:29:23 ERROR (MainThread) [supervisor.homeassistant] Error on call http://172.30.32.1:8123/api/config:
I am in the process of elimination so, if I can discount this error, I can go on to the next troubleshoot.
