TRV Anti-Seize Maintenance (Multi-Zone, Dynamic Limits & Boiler Shutoff)
With the heating off for the warmer months, one of the most common issues is TRVs seizing up from lack of use. I put together a blueprint to automate the exercise of these valves, keeping the pins moving without accidentally firing up your boiler.
Key Features
  • Target ALL or Specific TRVs: Use a single boolean toggle to automatically pull in every climate entity in your instance, or leave it off to manually select specific zones.
  • Dynamic Temperature Limits: No hardcoded temperatures. The blueprint reads the max_temp and min_temp attributes directly from your specific TRVs to push them to their physical limits.
  • Safe Heating Cutoff: Select any switches, relays, or booleans (like your boiler relay or zone valves) to safely turn them off before the valves open.
  • Seamless State Restoration: The automation takes a scene snapshot right before starting and restores your TRVs and heating sources to their exact prior states once the cycles are complete.
  • Adjustable Travel Delay: Customize the delay duration to ensure your specific brand of TRV has enough time to mechanically move from fully closed to fully open.
Import Blueprint
You can import the blueprint directly into your Home Assistant instance using the link below:
