I have a strange issue with the above TRVs. I upgraded Home Assistant 2025.02.0 and noticed (not sure if this happened because of the upgrade though / this may have been an issue before) that the above TRV’s climate entity on my Radiator dashboard were no longer working. The should as “n/a”
I went to my zigbee device list and they were there and when trying to add them to the my dashboard again, H/A suggested two different entities. A “none available” climate entity and one that works. I added the one that worked, modified the yaml to remove what I didn’t want to see and it seems to be OK again. So I guess there is an issue in the “quirk” (I use “ts0601_trv_me167.py”) and I wanted to report this but I can’t figure out who maintains this quirk: so I can’t.
Has anyone else noticed anything similar and/or can point me to the “quirk owner” so I can discuss it with them?
Thank you
