I haven’t been working with HA for that long and I’m trying out everything.
I now have the following problem:
I have a list of names and try each part of this list in an equation and if the equation is “True” some action needs to happen. Try this with a loop to shorten my code and give it a try, but it won’t work!!
Does anyone have a good solution for this?
My code is as follows:
{% for Naam in ("maud", "bart","elke","stijn") %}
{% if states("variable.verjaardag_" + Naam).split()[0:2]|join(' ') ==
now().strftime('%d') + ' ' + states.sensor.maand.state %}
{% set N= state_attr("variable.verjaardag_" + Naam,"friendly_name").split()[-1] %}
{% endif %}
{{N}}
{% endfor %}
Sorry for any serious mistakes and less good English, but for me this is a learning process!
Thanks for every tip and help
Greetings Bart
What you have posted is a template that will print a series of values… it is not an automation.
It would be helpful if you describe what your goal for the template is and post the automation that it is to be used in. Additionally, when using a custom setup like the variables integration you should show an example of the state and attributes of you entities (for privacy this can be a fake name and birthday, as long as it shares the same structure and formats as the entities you are trying to work with)
From what you have posted it looks like you have a set of variable entities, each of which have a state representing a person’s birthday. You seem to be trying to test whether today matches any of those dates and then outputting the name of the person.
