Hi, really sorry if this is an old question.
I just got the Home assistant green and it is working as far as turning on lights.
I have a Sonoff water sensor, SNZB-05P, and it seems to works ok, it shows dry and wet when I short the probes.
I wanted to try a simple automation so when the sensor detected water the action was to turn on a Hue bulb.
If I run the test it turns on light but nothing happens when it’s enabled.
I assumed if enabled it would run.
Not sure what yaml is but this is what I see:
alias: water on
description: “Water in Basement”
triggers:
Thanks for the comments, guess I’m too old school to understand most of what’s said in most of the topics.
I have got most functions to work for now. I’m sure my poking around is not the most efficient or correct way but it’s like trying to learn Greek when you only have Greeks explaining it.
I had no idea being a programmer was a prerequisite.
