Trying get tabbed card working
Getting no errors with this code - I am just getting black screen. all card types installed and HA restarted. Help would be appreciated.
type: custom:tabbed-card
tabs:
  - title: "Tab 1"
    type: custom:vertical-stack-in-card
    cards:
      - type: markdown
        content: "{{ states('sensor.lexmark_mc3224i_modelno') }}"
        card_mod:
          style: |
            ha-card {
              font-size: 15px;
              margin-bottom: -10px;
              border-bottom: none;
              border-radius: 10px 10px 0px 0px;
      - type: entities
        card_mod:
          style: |
            ha-card {
              border-top: none;
              border-radius: 0px 0px 10px 10px;
        entities:
          - entity: sensor.lexmark_mc3224i
          - entity: sensor.lexmark_mc3224i_uptime
          - entity: sensor.lexmark_mc3224i_serialno
          - entity: sensor.lexmark_mc3224i_firmwarever
      - type: custom:bar-card
        direction: right
        entities:
          - color: Magenta
            entity: sensor.lexmark_mc3224i_magenta
          - color: Yellow
            entity: sensor.lexmark_mc3224i_yellow
          - color: Cyan
            entity: sensor.lexmark_mc3224i_cyan
          - color: Black
            entity: sensor.lexmark_mc3224i_black
        height: 30px
        max: 100
        min: 0
        padding: 2px
        title_position: bottom
        icon_position: inside
        unit_of_measurement: "%"
        width: 100%
You are not following the instructions…where did you ‘invent’ - title: ?
RTM
kinghat/tabbed-card: a custom card for home assistant that utilizes tabs to segregate individual cards.
I was looking at example I saw somewhere, but even with the mistake present or not present I got no errors and black screen. thanks for pointing this out. I was hoping to make the card I have into tabbed card without doing a complete rewrite which probably would not work - existing card code provided by someone on these forums
It is hardly more work imo and always first (!) look at the card/integration instructions when having issues. Things may have changed, card may no longer be supported, etc. :slight_smile:
I got the tabs, but seeming the same info in both. Wondering if you or someone else can see what is wrong:
styles: ...
tabs:
  - attributes:
      label: Button
    card:
      cards:
        - type: markdown
          card_mod:
            style: |
              ha-card {
                font-size: 15px;
        - type: entities
          card_mod:
            style: |
              ha-card {
                border-top: none;
          entities:
  - attributes:
      label: Ink
    card:
      type: type: custom:bar-card
          direction: right
          entities:
            - color: Magenta
            - color: Yellow
            - color: Cyan
            - color: Black
          height:
One card per tab I guess, not sure but also here the ‘example’ shows 1/tab
EDIT: if you want to have more then likely you have to wrap them in a vertical stack card, where the vertical stack will be the single card for the tab
any ideas why same content appears on both tabs. if this code is way more than needed suggestions on what to remove would be appreciated. just need a functional card with tabs.
With ANY issue observed, use a simple principle: SIMPLIFY. Check with a tab-card with 2 simplest tabs with simplest STOCK cards.
