Thanks for the idea, I’m actually toying with the idea of using a “dummy” switch, that’s not connected to anything in my house, to trigger something inside Node Red when a Dash Button is pressed (I’m running HASSIO) I’ll play around with it to see if I can make it work.
Looks like it’s not HASSIO friendly. I’m going with the idea of having the Dash button toggle a “dummy” switch in my system and then use Node-Red to monitor said switch and perform automations from there. NOTE: Already working great with DASSHIO add-on inside HA, it’s the friendly version of Dasher for HASSIO users.
