Trying to cast Lovelace to Google Nest Hub. Ends with error "Not the same HA instance"
Hi, I am trying to cast my Lovelace dashboard to a Google Nest Hub. And run in to an error. Hope someone has a good idea!
I go to https://cast.home-assistant.io/ and enter my nubu.casa url.
Then I log in to my HA. and select the appropriate google nest hub. Then the Google Nest Hub indicates that it is connected. And I get an overview of my HA Views. When I click one of my views it gives an Error on the Google Nest hubs Display “Error: Cannot show Lovelace because we’re not connected to the same Home Assistant instance.”. it’s a bit strange because I do see my own HA views on de cast webpage it looks like the same instance. Maybe i have to contect Nubu Casa for this problem?
I have exactly the same problem. Trying to debug it but I’m not getting very far. I’ll post an update if I get anywhere.
I had the same problem, I solved it by configuring the “external_url:” variable in my “configuration.yaml”. This is because HA Cast requires “https” and the cast integration will cast from the “external_url” variable if configured.
For example in “configuration.yaml”:
    homeassistant:
         external_url: "https://example.duckdns.org:8123"
See first note on this page: Google Cast - Home Assistant
Are you also using Home Assistant Cloud? And does this also go wrong when selecting the view?
Thx Adrian, I already tried that but it didn’t work for me. I use Home Assistant Cloud so I shouldn’t need it in my configuration.yaml. Still I have tried your option with the cloud address https://***********.ui.nabu.casa
The strange thing is that it does connect. but when selecting the view. the message appears.
Okay, have you tried the method of casting the dashboard by using a script instead?
This video tutorial might help you: Use Google Displays with Home Assistant 2022 Update - YouTube
You are the best @Softaren it works!! :hugs: verry simple and even beter option to do it with a script!
Works perfectly for me too. Thanks @Softaren
I used this method but almost all of my dashboards are coming back blank. Just a black screen.
I tried creating a new view with only one card and it worked but the rest come back empty. Any ideas?
hi, one question:
Is it important to be a nabu casa subscriber?
:unamused:
